Fastled issue
Hello all
I know you like the code to be shown... out in the truck at the moment, but when I get back I can upload if required.
RGB addressable strip. All going fine with Fastled library.
Except... when I issue this command:
if (Led_Col==1);{leds1[Led_Tilt_Pos] = CRGB(255, 0, 0);FastLED.show();} (Hope I remembered that right).
It is changing all the LED colours, and not just the one at the position 'Led_Tilt_Pos'.
Is there a list of Fastled functions anywhere? I Googled and failed. Not 100% I am using the correct function to illuminate a single led.
OK... commented out various lines...
leds1[6] = CRGB(255,255,255);FastLED.show();
This illuminates led number 7 as it should in white, but it changes all the other leds in the strip to blue?
Comment this line out, and everything works as it should.
Is this not the correct way of illuminating a single led?
You really need to post your complete program or a smaller but complete program that illustrates the problem. Without that we have no way of knowing how and where leds1[] is declared for example.
Your command is correct, as Bob says there must be a problem somewhere else that makes you think it's here.
(deleted)
(deleted)
I am trying to find a list of the Fastled commands that isn't madly complicated.
Just found Fastled.clear... that removes my for loop statements to clear the whole strip for starters
I did not look at your code.
To swap colours
FastLED.addLeds<WS2812B, DATA_PIN, [b][color=red]GRB[/color][/b]>(leds, NUM_LEDS);
Did you look @spycatcher2k's reply #4.
Yes.. I saw reply 4. That line is commented out, so it's not that.
FastLED wiki works for me
You can call Serial.flush() after a Serial.print() to guarantee that the Serial buffer is emptied before continuing.
void Change_barrel () {
  Serial.println("Change barrel routine");
  Serial.flush();
Serial.print() will happily work without blocking till the Serial buffer is full. You can check how much you can still write to the buffer using Serial.availableForWrite() and do not write to the buffer if there is insufficient space.
  if(Serial.available() >23)
    skip the print
or a blocking version
  // wait till there is sufficient space
  while(Serial.available() < 23);
Note:
21 is the size of the text Change barrel routine; 2 extra added for
You are writing out of bounds...
void Illuminate_barrel () {        //Light the barrel
  if (Barrel > 0) {
    for (int g = 0; g < NUM_LEDS1 / 1.8; g++) {
      if ((Barrel > 6) and (Barrel < 10)) {
        g++; //If every other led required, then skip the count
      leds1[g] = CRGB(Green, Red, Blue);
      leds1[NUM_LEDS1 - g] = CRGB(Green, Red, Blue);
      FastLED.show();
      delay(6);
first time through the loop, g = 0 so you are writing to leds1[NUM_LEDS1].
I would second the advise about putting this together in pieces..
blh64:
Totally agree with you there ! but hey it's Fastled !
But isn't the first led address 0?
Steve-SFX:
Yes, but the last LED is not NUM_LEDS, but NUM_LEDS-1. Array index starts at 0, so final element is (length-1) not (length).
blh64:
Nice catch, karma added
Gotcha.... thank you for that.
I have re-written the code so that it sets the RGB colours, and only updates the strip once a loop, rather than updating every time something changes.
Seems to be OK at the moment.
Thank you for all advice!
