Hi. Wondering if anyone here has had success using the fastLED library with Adafruit’s ESP8266 Huzzah:
http://fastled.io/
I currently have the Hardware SPI pins on the Huzzah connected to 2 concatenated DotStar strips totaling 120 LEDs.
The setup works fine with Adafruit’s DotStar library, now I want to try it with fastLED. Again, using Hardware SPI.
The sketch is fastLED’s FirstLight example with all the comments and commented-out statements removed:
#include "FastLED.h"
#define NUM_LEDS 120
CRGB leds[NUM_LEDS];
delay(2000);
FastLED.addLeds<DOTSTAR, RGB>(leds, NUM_LEDS); // <-- This line is one of the choices in the original FirstLight example. It should specify use of Hardware SPI
for (int whiteLed = 0; whiteLed < NUM_LEDS; whiteLed = whiteLed + 1) {
leds[whiteLed] = CRGB::White;
FastLED.show();
delay(100);
leds[whiteLed] = CRGB::Black;
The list of compiler errors is so massive that it pushes this post over the 9000 character limit. So, it’s attached.
Any guidance would be appreciated.
Thanks.
Compiler Errors.txt (9.9 KB)
