Fastled pallettes and other sequnces
/// @file    ColorPalette.ino
/// @brief   Demonstrates how to use @ref ColorPalettes
/// @example ColorPalette.ino
#include <FastLED.h>
#define LED_PIN     2
#define NUM_LEDS    60
#define BRIGHTNESS  64
#define LED_TYPE    WS2811
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
#define UPDATES_PER_SECOND 500
// This example shows several ways to set up and use 'palettes' of colors
// with FastLED.
// These compact palettes provide an easy way to re-colorize your
// animation on the fly, quickly, easily, and with low overhead.
// USING palettes is MUCH simpler in practice than in theory, so first just
// run this sketch, and watch the pretty lights as you then read through
// the code.  Although this sketch has eight (or more) different color schemes,
// the entire sketch compiles down to about 6.5K on AVR.
// FastLED provides a few pre-configured color palettes, and makes it
// extremely easy to make up your own color schemes with palettes.
// Some notes on the more abstract 'theory and practice' of
// FastLED compact palettes are at the bottom of this file.
CRGBPalette16 currentPalette;
TBlendType    currentBlending;
extern CRGBPalette16 myRedWhiteBluePalette;
extern const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM;
    delay( 3000 ); // power-up safety delay
    FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
    FastLED.setBrightness(  BRIGHTNESS );
    FastLED.setMaxPowerInVoltsAndMilliamps(5,1000);
    currentPalette = myRedWhiteBluePalette_p;
    currentBlending = NOBLEND;
    ChangePalettePeriodically();
    static uint8_t startIndex = 0;
    startIndex = startIndex + 1; /* motion speed */
    FillLEDsFromPaletteColors( startIndex);
    FastLED.show();
    //FastLED.delay(1000 / UPDATES_PER_SECOND);
    FastLED.delay(5);
void FillLEDsFromPaletteColors( uint8_t colorIndex)
    uint8_t brightness = 255;
    for( int i = 0; i < NUM_LEDS; ++i) {
        leds[i] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending);
        colorIndex += 3;
// There are several different palettes of colors demonstrated here.
// FastLED provides several 'preset' palettes: RainbowColors_p, RainbowStripeColors_p,
// OceanColors_p, CloudColors_p, LavaColors_p, ForestColors_p, and PartyColors_p.
// Additionally, you can manually define your own color palettes, or you can write
// code that creates color palettes on the fly.  All are shown here.
void ChangePalettePeriodically()
    uint8_t secondHand = (millis() / 1000) % 120;
    //static uint8_t lastSecond = 99;
      static uint8_t lastSecond = 130;
    if( lastSecond != secondHand) {
        lastSecond = secondHand;
        if( secondHand == 10)  { SetupRedBlueAndWhitePalette();             currentBlending = LINEARBLEND; }
        if( secondHand == 20)  { SetupBlackAndWhiteStripedPalette();       currentBlending = NOBLEND; }
        if( secondHand == 25)  { SetupBlackAndWhiteStripedPalette();       currentBlending = LINEARBLEND; }
        if( secondHand == 30)  { SetupBlackAndRedStripedPalette();       currentBlending = NOBLEND; }
        if( secondHand == 35)  { SetupBlackAndRedStripedPalette();       currentBlending = LINEARBLEND; }
        if( secondHand == 40)  { SetupBlackAndBlueStripedPalette();       currentBlending = NOBLEND; }
        if( secondHand == 45)  { SetupBlackAndBlueStripedPalette();       currentBlending = LINEARBLEND; }
        if( secondHand == 50)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = NOBLEND;  }
        if( secondHand == 55)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = LINEARBLEND; }
        if( secondHand == 60)  {NewKITT(0xff, 0, 0, 8, 10, 50);}
// This function sets up a palette of black and white stripes,
// using code.  Since the palette is effectively an array of
// sixteen CRGB colors, the various fill_* functions can be used
// to set them up.
void SetupBlackAndWhiteStripedPalette()
    // 'black out' all 16 palette entries...
    FastLED.clear();
    FastLED.show();
    fill_solid( currentPalette, 16, CRGB::Black);
    // and set every fourth one to white.
    currentPalette[0] = CRGB::White;
    currentPalette[4] = CRGB::White;
    currentPalette[8] = CRGB::White;
    currentPalette[12] = CRGB::White;
void SetupBlackAndRedStripedPalette()
    currentPalette[0] = CRGB::Red;
    currentPalette[4] = CRGB::Red;
    currentPalette[8] = CRGB::Red;
    currentPalette[12] = CRGB::Red;
void SetupBlackAndBlueStripedPalette()
    currentPalette[0] = CRGB::Blue;
    currentPalette[4] = CRGB::Blue;
    currentPalette[8] = CRGB::Blue;
    currentPalette[12] = CRGB::Blue;
// This function sets up a palette of red and blue stripes.
void SetupRedBlueAndWhitePalette()
    CRGB red = CHSV( HUE_RED, 255, 255);
    CRGB blue  = CHSV( HUE_BLUE, 255, 255);
    CRGB white  = CRGB::Grey;
    currentPalette = CRGBPalette16(
                                   red,  red,  white,  white,
                                   blue, blue, white,  white,
                                   blue, blue, white,  white );
// This example shows how to set up a static color palette
// which is stored in PROGMEM (flash), which is almost always more
// plentiful than RAM.  A static PROGMEM palette like this
// takes up 64 bytes of flash.
const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM =
    CRGB::Red,
    CRGB::Gray, // 'white' is too bright compared to red and blue
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Black
void NewKITT(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  RightToLeft(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  LeftToRight(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  OutsideToCenter(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
  CenterToOutside(red, green, blue, EyeSize, SpeedDelay, ReturnDelay);
void CenterToOutside(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i =((NUM_LEDS-EyeSize)/2); i>=0; i--) {
    setAll(0,0,0);
    setPixel(i, red/10, green/10, blue/10);
    for(int j = 1; j <= EyeSize; j++) {
      setPixel(i+j, red, green, blue);
    setPixel(i+EyeSize+1, red/10, green/10, blue/10);
    setPixel(NUM_LEDS-i, red/10, green/10, blue/10);
      setPixel(NUM_LEDS-i-j, red, green, blue);
    setPixel(NUM_LEDS-i-EyeSize-1, red/10, green/10, blue/10);
    FastLED.show();
    delay(SpeedDelay);
  delay(ReturnDelay);
void OutsideToCenter(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i = 0; i<=((NUM_LEDS-EyeSize)/2); i++) {
    setAll(0,0,0);
    FastLED.show();
    delay(SpeedDelay);
  delay(ReturnDelay);
void LeftToRight(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i = 0; i < NUM_LEDS-EyeSize-2; i++) {
    setAll(0,0,0);
    FastLED.show();
    delay(SpeedDelay);
  delay(ReturnDelay);
void RightToLeft(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay) {
  for(int i = NUM_LEDS-EyeSize-2; i > 0; i--) {
    setAll(0,0,0);
    FastLED.show();
    delay(SpeedDelay);
  delay(ReturnDelay);
// Set all LEDs to a given color and apply it (visible)
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
    setPixel(i, red, green, blue);
    FastLED.show();
// Set a LED color (not yet visible)
void setPixel(int Pixel, byte red, byte green, byte blue) {
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
// Additional notes on FastLED compact palettes:
// Normally, in computer graphics, the palette (or "color lookup table")
// has 256 entries, each containing a specific 24-bit RGB color.  You can then
// index into the color palette using a simple 8-bit (one byte) value.
// A 256-entry color palette takes up 768 bytes of RAM, which on Arduino
// is quite possibly "too many" bytes.
// FastLED does offer traditional 256-element palettes, for setups that
// can afford the 768-byte cost in RAM.
// However, FastLED also offers a compact alternative.  FastLED offers
// palettes that store 16 distinct entries, but can be accessed AS IF
// they actually have 256 entries; this is accomplished by interpolating
// between the 16 explicit entries to create fifteen intermediate palette
// entries between each pair.
// So for example, if you set the first two explicit entries of a compact
// palette to Green (0,255,0) and Blue (0,0,255), and then retrieved
// the first sixteen entries from the virtual palette (of 256), you'd get
// Green, followed by a smooth gradient from green-to-blue, and then Blue.
Everything works fine, except my NewKITT function only runs once. I would think it would run for 60 secs (120-60). When I remove the semicolon in line 193 the error message is "NewKITT not declared in this scope". If I leave the semicolon in the NewKITT sequence only runs once.
I hope to add more non-pallette sequences (functions) to fill the 120 secs, see line 87.
Also, what is the significance of line 89, last second. I don't see much impact on the lights.
Thanks.
Try 255 rather than 0xff. Would you describe how it should work, and how it does not work?
Disregard. Sry.
Well, at this point the NewKITT function should run for 60 secs. It only runs for one of these cycles
which is a lot less than 60 secs.
You call four functions, twice. What is the duration for calling the four once?
I am calling essentially 10 functions. Some are NOBLEND, some are LINEARBLEND.
Sorry, in NewKITT(), there are four functions called twice each. What effect, if any, does calling them once make?
And... does the PROGMEM line need a datatype (after const)?
NewKITT has a sequence like the image.
Also,
works fine.
So how long should NewKITT not run after it has gone through a sixty second cycle?
    if ( secondHand == 60)  {
According to this, NewKITT will only run for one second or less.
No. The cycle time for all the light sequences is 120. Newkitt should run for 60.
I think a clue is the semicolon. But I don't know how to interpret the clue.
It should Not run for another 60 seconds as the other sequences run.
So it's on for sixty then off for sixty?
Yes. That's how it is meant to work. But it only stays on for a few seconds.
Well I've made a little progress.
When I place 'void NewKit't function inside the semicolon, above void SetupRedBlueAndWhitePalette()
#define LED_PIN     2
#define NUM_LEDS    60
// with FastLED.
    FastLED.show();
    FastLED.delay(5);
        colorIndex += 3;
    uint8_t secondHand = (millis() / 1000) % 80;
        if( secondHand == 70)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = LINEARBLEND; }
// to set them up.
    FastLED.clear();
    FastLED.show();
    CRGB::Red,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Black
    setAll(0,0,0);
    FastLED.show();
    delay(SpeedDelay);
  delay(ReturnDelay);
    setAll(0,0,0);
    FastLED.show();
    delay(SpeedDelay);
  delay(ReturnDelay);
    setAll(0,0,0);
    FastLED.show();
    delay(SpeedDelay);
  delay(ReturnDelay);
    setAll(0,0,0);
    FastLED.show();
    delay(SpeedDelay);
  delay(ReturnDelay);
    FastLED.show();
the NewKITT sequence runs for one complete sequence, but not for the amount of time (10 secs) specified in:
Any suggestions would be appreciated.
