FastLed - Reading values
I'm doing a project that uses the FastLed library to drive some WS2811 pixels.
I'm also driving some other "pixels" (as well as the WS2811) that are DMX controlled using another library (Conceptinetics).
I'm waiting for a FastLed.show() then calling my "FastLED to DMX function" :
void doDMX(){
for (int i=0; i<NUM_LEDS; i++) {
dmx_master.setChannelValue(i3+1, (int) leds.r);*
dmx_master.setChannelValue(i3+2, (int) leds.g);
dmx_master.setChannelValue(i3+3, (int) leds*.b);
_ int test = (int) leds.r;
Serial.print(test);
}_
_My read of the FastLed documentation suggests leds.r should be a byte representing red with a value from 0-255.
When I try to compile I get
HardwareSerial0.cpp.o (symbol from plugin): In function Serial': (.text+0x0): multiple definition of __vector_18'
libraries\Conceptinetics\Conceptinetics.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
I have the Serial.print in there to aid debugging. Obviously things don't work as expected regardless :wink: Have tried a few variation without luck.
What have I missed here?
Thanks!_
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
Also posting all your code is always advised because often, like in this case, the error is not where you think it is.
That error message is saying there is a clash with a software serial instance and something else, probably something that wants to use the pin change interrupt mechanism.
Domestic blindness at its finest :o
I totally missed the code button and wound up using Teletype instead. I did try it manually but used tags not
Cheers!
