FastLed Won't show colors after receiving correct input from C# application
Hello everyone!
Today I got an error, whilst programming a ledstrip that uses FastLed.H.
First I used a NeoPixel Ledstrip from Adafruit (144 Leds), and then the code worked correctly, but when I added Fastleds (I got a few more led strips of those than the NeoPixel from Adafruit), and the leds won’t change the correct ones into the appropriate color.
Do I write wrong from the ledWrite Method towards the SetSingleFastLed method? Or is the error in the variable type?
Code:
#include <FastLED.h>
#define NumberOfLedsOnFastLedStrip 60
#define DataPinForFastLedLedstrip 5
CRGB FastLeds[NumberOfLedsOnFastLedStrip];
#define TotalNumberOfLeds (144)
#define InputPin (9)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(TotalNumberOfLeds, InputPin, NEO_RGB + NEO_KHZ800);
byte bytesReceived[5];
int coupeNr;
int currentCapacity;
int lengthCoupe;
int startingPoint;
void UpdateStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
  // If NeoPixel Is Defined
  strip.show();
#endif
void SetSingleNeoPixel(int NeoPixel, byte G, byte R, byte B) {
  strip.setPixelColor(NeoPixel, strip.Color(G, R, B));
  UpdateStrip();
#endif
void SetSingleFastled(int FastLed, uint8_t R, uint8_t G, uint8_t B)
  //FastLeds[FastLed].setRGB(R,G,B);
  FastLeds[FastLed].r = R;
  FastLeds[FastLed].g = G;
  FastLeds[FastLed].b = B;
FastLED.show();
void SetAllNeoPixels(byte G, byte R, byte B) {
  for (int i = 0; i < TotalNumberOfLeds; i++ ) {
    SetSingleNeoPixel(i, G, R, B);
  UpdateStrip();
  FastLED.addLeds<NEOPIXEL, DataPinForFastLedLedstrip>(FastLeds, NumberOfLedsOnFastLedStrip);
  strip.begin();
  strip.setBrightness(10);
  SetAllNeoPixels(255, 255, 255);
  strip.show();
  fill_solid(FastLeds, 60, CRGB(255, 0, 0));
  FastLED.show();
  delay(2000);
  fill_solid(FastLeds, 60, CRGB(0, 0, 0));
  FastLED.show();
  if (Serial.available() > 0) {
    while (Serial.available() > 0) {
      Serial.readBytes(bytesReceived, 5);//lees de bytes van serial en sla ze op in een array
    delay(2);
    coupeNr = bytesReceived[0];
    currentCapacity = bytesReceived[1];
    lengthCoupe = bytesReceived[2];
    byte startingPointHigh = bytesReceived[3];
    byte startingPointLow = bytesReceived[4];
    startingPoint = (startingPointHigh << 8) | startingPointLow; // Because starting point can be bigger than 255, we will need to apply Bit Manipulation
    ledWrite(coupeNr, currentCapacity, lengthCoupe, startingPoint);
void ledWrite(int coupeInput, int peopleInput, int coupeLength, int startingPoint) {
  int R;
  int G;
  int B;
  if (peopleInput < 100) {
    R = 2.5 * peopleInput;
    G = 255 - (2.5 * peopleInput);
    B = 0;
  if (peopleInput >= 100) {
    R = 255;
    G = 0;
    B = 0;
uint8_t fastR = R;
uint8_t fastG = G;
uint8_t fastB = B;
  for (int i = (coupeLength * coupeInput) + startingPoint; i < coupeLength + (coupeInput * coupeLength) + startingPoint; i++) { //berekening om de LEDs op de juiste plek aan te zetten
   // SetSingleNeoPixel(i, G, R, B);
    SetSingleFastled(i, R, G, B);
I already looked around for the reason, and tried a few CRGB functions out, but they did not fix the problem. I even made Unsigned Ints before the for loop, but it still did not work.
The ledstrip works though when I upload it to the Arduino (with the Fill_Solid Function).
So my question is: Can someone give me a few pointers on where the error lies, or show me what I am doing wrong?
Thank you all in advance, and I wish you all a nice day.
You can not use both the fastLED and the Adafruit library in the same sketch.
Grumpy_Mike:
May I ask why?
Is it because Fastled accesses and assigns the same resources Adafruit does?
also thanks for the answer, the code works now! :smiley:
May I ask why?
I think it is because of overloading, that is using functions with the same name with the last to be defined overriding the functions of the earlier ones.
Grumpy_Mike:
I see.
Well the code works except for the last method (called LedWrite)
Do you know what I am doing wrong there? I am using long int since normal int’s do not equal the same amount of bytes.
Is it the formula that is used to calculate the I? or am I calling upon the CRGB values wrong? The ledstrip does work when called in the Setup(), but not in my own method.
int coupeNr;
int lengthCoupe;
int startingPoint;
  delay(2000);
      FastLED.setBrightness(255);
  fill_solid(FastLeds, 60, CRGB(0, 0, 255));
  FastLED.show();
  delay(2000);
  FastLED.show();
    delay(2);
    startingPoint = (startingPointHigh << 8) | startingPointLow; //omdat startingpoint groter dan 255 kan zijn moet bit manipulation worden toegepast
long  int R;
long  int G;
long  int B;
    B = 0;
    R = 255;
    G = 0;
    B = 0;
 FastLeds[i].setRGB(R,G,B);
   FastLED.show();
I would cast the variables to float when doing the calculations and cast them back to long in before assigning them to R G and B.
Grumpy_Mike: I would cast the variables to float when doing the calculations and cast them back to long in before assigning them to R G and B.
Something like this: long int fastR = (long int)R; long int fastG = (long int)G; long int fastB = (long int)B; ? Edit:
Did the long int cast, and still the ledstrip won't light up.
Or do you mean int R then cast toward a float before doing the if statements and after those and before the for loop I do the long int cast.
Thanks again for your help
I said cast to float
R = int()( 2.5 * float() peopleInput);
Grumpy_Mike:
so like this then:
  long int R;
  long int G;
  long int B;
    R = (long int)( 2.5 *(float) peopleInput);
    G = (long int) ( 255 - (2.5 * (float) peopleInput));
    B = 0;
    R = 255;
    G = 0;
    B = 0;
Seeing that you have to put the cast variable into the parenthesis, instead of putting them in front of them.
Would I also have to make the cast in the if >= 100? Would not make a lot of sense because the variable there is put to max of byte value and no calculation is needed.
No you are not using any mixed data type arithmetic.
