Hi All,
I consider myself to be a noob when it comes to arduino programming. However i managed to take an English word clock code and convert it to Dutch language. Also i have spend quite a few days to add OTA and NTP functionality and make it work properly. I am aware that the code is by no means perfect, has incorrect formatting and is not 100% optimal. But so far it worked for me...
After running the code for a while i noticed there is a small bug, and i really can not seem to find the cause of the issue. For some reason the DimAll and LitAll functions do not always seem to run as intended.
Upon time change (every 5 minutes) the leds would start dimming, but would stop at +/-10% brightness. The LitAll function then takes off from that 10% value (if that makes sense) Unfortunately this behaviour is not the same for every time change. Most of the times the leds will fade down to 0, but sporadically they stop before that.
My first thought was that the Wemos must be performing other tasks at the same time, causing the interrupt. I have experimented with delays on various positions with diffent values but i can not seem to get rid of the problem. I would be more then pleased if someone can take a look at the code below:
#include <Arduino.h>
#include <Wire.h>
#include <FastLED.h>
#include <DS3231.h> //https://github.com/jarzebski/Arduino-DS3231
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <ESP8266WiFi.h>
#include <NTPClient.h>
#include <ESP8266mDNS.h>
#define bcd2dec(bcd_in) (bcd_in >> 4) * 10 + (bcd_in & 0x0f)
#define dec2bcd(dec_in) ((dec_in / 10) << 4) + (dec_in % 10)
#define LED_PIN 14
#define NUM_LEDS 110
#define BRIGHTNESS 80
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
const char* ssid = "iamnotpostingmyssid";
const char* password = "ormypassword";
DS3231 clock1;
RTCDateTime dt;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org");
byte mByte[0x03];
byte tByte[0x03];
const long gmtOffset = 7200;
int minutes;
int hours;
int CurrentTime[5];
int PreviousTime[4];
int Time_Comp[22][6]{ { 56, 57, 58,999,999,999},
{ 44, 45, 46, 47,999,999},
{ 51, 52, 53, 54,999,999},
{ 40, 41, 42, 43,999,999},
{ 36, 37, 38, 39,999,999},
{ 33, 34, 35,999,999,999},
{ 22, 23, 24, 25, 26,999},
{ 18, 19, 20, 21,999,999},
{ 28, 29, 30, 31, 32,999},
{ 14, 15, 16, 17,999,999},
{ 11, 12, 13,999,999,999},
{ 0, 1, 2, 3, 4, 5},
{ 73, 74, 75, 76,999,999},
{ 95, 96, 97, 98,999,999},
{ 99,100,101,102,999,999},
{ 88, 89, 90, 91,999,999},
{ 77, 78, 79, 80, 81,999},
{ 8, 9, 10,999,999,999},
{ 66, 67, 68, 69,999,999},
{104,105,107,108,109,999},
{ 84, 85, 86, 87,999,999},
{ 62, 63, 64, 65,999,999}};
void LitAll(){
for(int i=0;i<=80;i++){
LEDS.setBrightness(i);
FastLED.show();
delay(60);
void DimAll(){
for(int i=80;i>=0;i--){
FastLED.show();
delay(60);
void setup(){
Wire.begin();
WiFi.begin(ssid, password);
ArduinoOTA.begin();
delay(5000);
UpdateTime();
FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setBrightness( BRIGHTNESS );
ArduinoOTA.handle();
WordTime();
if (PreviousTime[0]!=CurrentTime[0] or PreviousTime[1]!=CurrentTime[1]) {
DimAll();
if (PreviousTime[0]!=99) for (int j=0;j<6;j++) leds[Time_Comp[PreviousTime[0]][j]]=CHSV( 0 , 0, 0);
if (PreviousTime[1]!=99) for (int j=0;j<6;j++) leds[Time_Comp[PreviousTime[1]][j]]=CHSV( 0 , 0, 0);
if (PreviousTime[2]!=99) for (int j=0;j<6;j++) leds[Time_Comp[PreviousTime[2]][j]]=CHSV( 0 , 0, 0);
if (PreviousTime[3]!=99) for (int j=0;j<6;j++) leds[Time_Comp[PreviousTime[3]][j]]=CHSV( 0 , 0, 0);
if (CurrentTime[0]!=99) for (int j=0;j<6;j++) leds[Time_Comp[CurrentTime[0]][j]]=CRGB::Blue;
if (CurrentTime[1]!=99) for (int j=0;j<6;j++) leds[Time_Comp[CurrentTime[1]][j]]=CRGB::Blue;
if (CurrentTime[2]!=99) for (int j=0;j<6;j++) leds[Time_Comp[CurrentTime[2]][j]]=CRGB::Blue;
if (CurrentTime[3]!=99) for (int j=0;j<6;j++) leds[Time_Comp[CurrentTime[3]][j]]=CRGB::Blue;
if (CurrentTime[4]!=99) for (int j=0;j<6;j++) leds[Time_Comp[CurrentTime[4]][j]]=CRGB::Blue;
LitAll();
UpdateTime();
void getRTCdatetime(){
Wire.beginTransmission (0x68);
Wire.write (0x00);
Wire.endTransmission ();
Wire.requestFrom(0x68, 0x03, true);
int idx = 0;
while(Wire.available()){
byte input = Wire.read();
mByte[idx] = input;
idx++;
Serial.print(F("Register[0] Seconds: ")); Serial.println(bcd2dec(mByte[0]));
Serial.print(F("Register[1] Minutes: ")); Serial.println(bcd2dec(mByte[1]));
Serial.print(F("Register[2] Hours: ")); Serial.println(bcd2dec(mByte[2]));
Serial.println("\n");
void UpdateTime(){
timeClient.begin();
timeClient.setTimeOffset(gmtOffset);
Serial.println(F("DS3231 register content...\n"));
getRTCdatetime();
if (WiFi.status() == WL_CONNECTED) timeClient.update();
unsigned long epochTime = timeClient.getEpochTime();
tByte[0] = (int)timeClient.getSeconds();
tByte[1] = (int)timeClient.getMinutes();
tByte[2] = (int)timeClient.getHours();
Serial.print(F("NTP Webtime...\n\n"));
Serial.print("Seconds: "); Serial.println(tByte[0]);
Serial.print("Minutes: "); Serial.println(tByte[1]);
Serial.print("Hours: "); Serial.println(tByte[2]);
Serial.print("\n");
if((mByte != tByte) and (WiFi.status() == WL_CONNECTED)){
Wire.write (0x00);
for (int idx = 0; idx < 3; idx++){
Wire.write (dec2bcd(tByte[idx]));
Serial.println(F("New DS3231 register content...\n"));
getRTCdatetime();
void WordTime(){
PreviousTime[0]=CurrentTime[0];
PreviousTime[1]=CurrentTime[1];
PreviousTime[2]=CurrentTime[2];
PreviousTime[3]=CurrentTime[3];
dt = clock1.getDateTime();
minutes=int((dt.minute)/5)*5;
if (minutes<20 and minutes>=0) hours=dt.hour ;else hours=dt.hour+1;
if (minutes==0) {CurrentTime[0]=17;CurrentTime[1]=99;}
if ((minutes==5) or (minutes==55)) {CurrentTime[0]=14;CurrentTime[1]=99;}
if ((minutes==10) or (minutes==50)) {CurrentTime[0]=15;CurrentTime[1]=99;}
if ((minutes==15) or (minutes==45)) {CurrentTime[0]=16;CurrentTime[1]=99;}
if ((minutes==20) or (minutes==40)) {CurrentTime[0]=15;CurrentTime[1]=18;}
if ((minutes==25) or (minutes==35)) {CurrentTime[0]=14;CurrentTime[1]=18;}
if (minutes==30) {CurrentTime[0]=18;CurrentTime[1]=99;}
if (minutes>= 5 and minutes<20) CurrentTime[2]=12;
if (minutes>=20 and minutes<=29) CurrentTime[2]=13;
if (minutes>=30 and minutes<=34) CurrentTime[2]=99;
if (minutes>=35 and minutes<=44) CurrentTime[2]=20;
if (minutes>=45 and minutes<=59) CurrentTime[2]=21;
if (minutes==0) CurrentTime[2]=99;
CurrentTime[3]=hours - int(hours/12)*12-1;
CurrentTime[4]=19;
if (CurrentTime[3]<0) CurrentTime[3]=CurrentTime[3]+12;
