FastLED (WS2812) and RF receiver issues
Hello all. I have written the following sketch to activate an LED effect when an RF code is received. If I send value 721409 (see sketch) using a remote for a split second, the effect works as expected. However if I press the button for only a few millis too long or press the button a second time, the effect “freezes” and I have to hit the button again to get it to restart.
My second issue is that I have to send the stop value (721413) twice to turn the LEDs off. Sending it once freezes the effect, sending it a second time turns it off. I’m assuming this is linked to the first issue, but I could be off the mark.
What am I doing wrong? Thanks in advance.
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
#include "FastLED.h"
#define NUM_LEDS 100
CRGB leds[NUM_LEDS];
#define PIN 4
unsigned long previousMillis = 0;
const long interval = 20;
void showStrip() {
  #ifndef ADAFRUIT_NEOPIXEL_H
    // FastLED
    FastLED.show();
  #endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
    // FastLED
    leds[Pixel].r = red;
    leds[Pixel].g = green;
    leds[Pixel].b = blue;
  #endif
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
    setPixel(i, red, green, blue);
  showStrip();
void Fire(int Cooling, int Sparking, int SpeedDelay) {
  static byte heat[NUM_LEDS];
  int cooldown;
  if(currentMillis - previousMillis > interval) {
    // Step 1.  Cool down every cell a little
    for( int i = 0; i < NUM_LEDS; i++) {
      cooldown = random(0, ((Cooling * 10) / NUM_LEDS) + 2);
      if(cooldown>heat[i]) {
        heat[i]=0;
        heat[i]=heat[i]-cooldown;
    // Step 2.  Heat from each cell drifts 'up' and diffuses a little
    for( int k= NUM_LEDS - 1; k >= 2; k--) {
      heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2]) / 3;
    // Step 3.  Randomly ignite new 'sparks' near the bottom
    if( random(255) < Sparking ) {
      int y = random(7);
      heat[y] = heat[y] + random(160,255);
      //heat[y] = random(160,255);
    // Step 4.  Convert heat to LED colors
    for( int j = 0; j < NUM_LEDS; j++) {
      setPixelHeatColor(j, heat[j] );
    showStrip();
void setPixelHeatColor (int Pixel, byte temperature) {
  // Scale 'heat' down from 0-255 to 0-191
  byte t192 = round(temperature);
  // calculate ramp up from
  byte heatramp = t192 & 0x3F; // 0..63
  heatramp <<= 2; // scale up to 0..252
  // figure out which third of the spectrum we're in:
  if( t192 > 0x80) {                     // hottest
    setPixel(Pixel, 255, 255, heatramp);
  } else if( t192 > 0x40 ) {             // middle
    setPixel(Pixel, 255, heatramp, 0);
  } else {                               // coolest
    setPixel(Pixel, heatramp, 0, 0);
  mySwitch.enableReceive(0);  // interrupt 0 = D2
  FastLED.addLeds<WS2812, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  setAll(0,0,0);
  if (mySwitch.available()) {
    unsigned long value = mySwitch.getReceivedValue();
    if (value == 721409) {
      Serial.println(mySwitch.getReceivedValue());
      Fire(40,120,10);
    if (value == 721413) { // off
      setAll(0,0,0);
      mySwitch.resetAvailable();
    //mySwitch.resetAvailable(); - don't use, stops effect immediately
Not familiar with the RCSwitch library, but why do you use
and not
Serial.println(value)
sterretje:
and not
Good question. I know there was some reason why I had that in one of my older sketches, but I don’t remember why so I just replaced it with your suggestion to clean up the code.
I noticed that with my code, the serial monitor spams 721409 (the "on" RF code) non-stop. If I remove the Serial.println bit, it doesn't spam it (obviously) and the effect runs flawlessly; hitting the button again does not freeze the effect. However in that case, hitting the off button does not work at all because the Arduino is busy the whole time.
