Now i have been googeling for a while now but i can’t fix this problem.
When using ESP32 i download this library: https://github.com/PaulStoffregen/SoftwareSerial
Then load the example skatch “SoftwareSerialExample”:
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Serial.begin(57600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("Goodnight moon!");
// set the data rate for the SoftwareSerial port
mySerial.begin(4800);
mySerial.println("Hello, world?");
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
While compiling i get this error message:
Arduino:1.8.8 (Mac OS X), Board:“ESP32 Dev Module, Disabled, Default, 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None”
Dropbox/Arduino/libraries/SoftwareSerial-master/SoftwareSerial.cpp:41:27: fatal error: avr/interrupt.h: No such file or directory
compilation terminated.
exit status 1
Fout bij het compileren voor board ESP32 Dev Module
This problem seems rare on the net?
Can enyone help?
- i have installed fresh arduino IDE
I have found that i should have to have a avr folder in the system library folder, but i don’t?
Is this right?
tnx a lot
