I was trying to use CoAP to retrieve data from dht11 using esp8266 but I received this small annoying error-fatal error: coapserver.h: No such file or directory.
Details are:
Arduino: 1.8.5 (Windows 8.1), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, All Flash Contents, 115200"
C:\Users\labpc 7\Documents\Arduino\coap-server\coap-server.ino:6:24: fatal error: coapserver.h: No such file or directory
#include <coapserver.h>
compilation terminated.
Multiple libraries were found for "ESP8266WiFi.h"
Used: C:\Users\labpc 7\Documents\Arduino\libraries\ESP8266WiFi
Not used: C:\Users\labpc 7\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
option enabled in File -> Preferences.
Even after copy-pasting coapserver.h in C:\Users\labpc 7\Documents\Arduino\coap-server and in C:\Users\labpc 7\Documents\Arduino\libraries\ESP8266WiFi still I am receiving the same error :fatal error: coapserver.h: No such file or directory. I am using the github code:
ESP-COAP Server
#include <ESP8266WiFi.h>
// CoAP server endpoint url callback
void callback_light(coapPacket &packet, IPAddress ip, int port, int obs);
coapServer coap;
//WiFi connection info
const char* ssid = "xxxxxxxxx";
const char* password = "xxxxxxxxx";
// LED STATE
bool LEDSTATE;
// CoAP server endpoint URL
void callback_light(coapPacket *packet, IPAddress ip, int port,int obs) {
Serial.println("light");
// send response
char p[packet->payloadlen + 1];
memcpy(p, packet->payload, packet->payloadlen);
p[packet->payloadlen] = NULL;
Serial.println(p);
String message(p);
if (message.equals("0"))
digitalWrite(16,LOW);
Serial.println("if loop");
else if (message.equals("1"))
digitalWrite(16,HIGH);
Serial.println("else loop");
char *light = (digitalRead(16) > 0)? ((char *) "1") :((char *) "0");
//coap.sendResponse(packet, ip, port, light);
if(obs==1)
coap.sendResponse(light);
coap.sendResponse(ip,port,light);
void callback_lightled(coapPacket *packet, IPAddress ip, int port,int obs) {
Serial.println("Lightled");
// send response
String message(p);
LEDSTATE = false;
LEDSTATE = true;
if (LEDSTATE) {
digitalWrite(5, HIGH) ;
if(obs==1)
coap.sendResponse("1");
coap.sendResponse(ip, port, "1");
//coap.sendResponse("1");
digitalWrite(5, LOW) ;
if (obs==1)
coap.sendResponse("0");
coap.sendResponse(ip, port, "0");
//coap.sendResponse("0");
yield();
//serial begin
WiFi.begin(ssid, password);
Serial.println(" ");
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
//delay(500);
yield();
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Print the IP address
// LED State
pinMode(16, OUTPUT);
digitalWrite(16, HIGH);
LEDSTATE = true;
pinMode(5, OUTPUT);
digitalWrite(5, HIGH);
//LEDSTATE = true;
// add server url endpoints.
// can add multiple endpoint urls.
coap.server(callback_light, "light");
coap.server(callback_lightled, "lightled");
// coap.server(callback_text,"text");
// start coap server/client
coap.start();
// coap.start(5683);
coap.loop();
Can anyone help me?
