hi,
please everyone, i have a question about using the dht11 sensor with the parola timemsg example. everytime that i try to compile i get an error that dht11 is missing. ive tried several
libraries and ive trying editting with notepad++ several different ways and the result is the same.
i wish to ask which version of the dht library and which IDE everyone is having success with?
the code
Arduino: 1.6.7 (Windows XP), Board: "Arduino/Genuino Uno"
C:\Program Files\Arduino1.6\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files\Arduino1.6\hardware" -hardware "C:\Documents and Settings\jmartens\Local Settings\Application Data\Arduino15\packages" -tools "C:\Program Files\Arduino1.6\tools-builder" -tools "C:\Program Files\Arduino1.6\hardware\tools\avr" -tools "C:\Documents and Settings\jmartens\Local Settings\Application Data\Arduino15\packages" -built-in-libraries "C:\Program Files\Arduino1.6\libraries" -libraries "C:\Documents and Settings\jmartens\My Documents\Arduino1.6\libraries" -fqbn=arduino:avr:uno -ide-version=10607 -build-path "c:\temp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files\Arduino1.6\libraries\MD_Parola\examples\Parola_Zone_TimeMsg\Parola_Zone_TimeMsg.ino"
C:\Program Files\Arduino1.6\arduino-builder -compile -logger=machine -hardware "C:\Program Files\Arduino1.6\hardware" -hardware "C:\Documents and Settings\jmartens\Local Settings\Application Data\Arduino15\packages" -tools "C:\Program Files\Arduino1.6\tools-builder" -tools "C:\Program Files\Arduino1.6\hardware\tools\avr" -tools "C:\Documents and Settings\jmartens\Local Settings\Application Data\Arduino15\packages" -built-in-libraries "C:\Program Files\Arduino1.6\libraries" -libraries "C:\Documents and Settings\jmartens\My Documents\Arduino1.6\libraries" -fqbn=arduino:avr:uno -ide-version=10607 -build-path "c:\temp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Program Files\Arduino1.6\libraries\MD_Parola\examples\Parola_Zone_TimeMsg\Parola_Zone_TimeMsg.ino"
WARNING: Spurious .github folder in 'Adafruit SSD1331 OLED Driver Library for Arduino' library
WARNING: Spurious .github folder in 'Adafruit DHT Unified' library
"C:\Program Files\Arduino1.6\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\variants\standard" "c:\temp\sketch\Parola_Zone_TimeMsg.ino.cpp" -o "nul"
"C:\Program Files\Arduino1.6\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\variants\standard" "-IC:\Program Files\Arduino1.6\libraries\MD_Parola\src" "c:\temp\sketch\Parola_Zone_TimeMsg.ino.cpp" -o "nul"
"C:\Program Files\Arduino1.6\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\variants\standard" "-IC:\Program Files\Arduino1.6\libraries\MD_Parola\src" "-IC:\Program Files\Arduino1.6\libraries\MD_MAX72XX\src" "c:\temp\sketch\Parola_Zone_TimeMsg.ino.cpp" -o "nul"
"C:\Program Files\Arduino1.6\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\variants\standard" "-IC:\Program Files\Arduino1.6\libraries\MD_Parola\src" "-IC:\Program Files\Arduino1.6\libraries\MD_MAX72XX\src" "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\libraries\SPI" "c:\temp\sketch\Parola_Zone_TimeMsg.ino.cpp" -o "nul"
"C:\Program Files\Arduino1.6\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\variants\standard" "-IC:\Program Files\Arduino1.6\libraries\MD_Parola\src" "-IC:\Program Files\Arduino1.6\libraries\MD_MAX72XX\src" "-IC:\Program Files\Arduino1.6\hardware\arduino\avr\libraries\SPI" "c:\temp\sketch\Parola_Zone_TimeMsg.ino.cpp" -o "c:\temp\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Program Files\Arduino1.6\libraries\MD_Parola\examples\Parola_Zone_TimeMsg\Parola_Zone_TimeMsg.ino:42:19: fatal error: dht11.h: No such file or directory
#include <dht11.h>
compilation terminated.
Multiple libraries were found for "MD_Parola.h"
Used: C:\Program Files\Arduino1.6\libraries\MD_Parola
Not used: C:\Program Files\Arduino1.6\libraries\MD_Parola-master
Using library MD_Parola at version 2.6.2 in folder: C:\Program Files\Arduino1.6\libraries\MD_Parola
Using library MD_MAX72XX at version 2.9.0 in folder: C:\Program Files\Arduino1.6\libraries\MD_MAX72XX
Using library SPI at version 1.0 in folder: C:\Program Files\Arduino1.6\hardware\arduino\avr\libraries\SPI
exit status 1
Error compiling.
Invalid library found in C:\Program Files\Arduino1.6\libraries\arduino: C:\Program Files\Arduino1.6\libraries\arduino
Invalid library found in C:\Program Files\Arduino1.6\libraries\Arduino_library: C:\Program Files\Arduino1.6\libraries\Arduino_library
Invalid library found in C:\Program Files\Arduino1.6\libraries\max7219: C:\Program Files\Arduino1.6\libraries\max7219
Invalid library found in C:\Documents and Settings\jmartens\My Documents\Arduino1.6\libraries\Arduino-master: C:\Documents and Settings\jmartens\My Documents\Arduino1.6\libraries\Arduino-master
im very sorry if its been answered before but i cannot find it myself.
ive tried search and reading the first seven pages of this particular post.
thank you for your hard work and time
jerry
