fatal error: etherShield.h: No such file or directory Help pls !!!
Hello Guys,
i just have the problem that my Arduino program give me every time a fatal error.
Thats the code:
#include “etherShield.h”
#include “ETHER_28J60.h”
int outputPin = 9;
static uint8_t mac[6] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24}; // this just needs to be unique for your network,
// so unless you have more than one of these boards
// connected, you should be fine with this value.
static uint8_t ip[4] = {192, 168, 1, 15}; // the IP address for your board. Check your home hub
// to find an IP address not in use and pick that
// this or 10.0.0.15 are likely formats for an address
// that will work.
static uint16_t port = 80; // Use port 80 - the standard for HTTP
ETHER_28J60 e;
e.setup(mac, ip, port);
pinMode(outputPin, OUTPUT);
char* params;
if (params = e.serviceRequest())
e.print(“
Web Remote
e.print(“Turn off”);
e.print(“Turn on”);
if (strcmp(params, “?cmd=on”) == 0)
digitalWrite(outputPin, HIGH);
//e.print(“Turn off”);
else if (strcmp(params, “?cmd=off”) == 0) // Modified – 2011 12 15 # Ben Schueler
digitalWrite(outputPin, LOW);
//e.print(“Turn on”);
/else ()
digitalWrite(outputPin,LOW);
e.respond();
After that every time it show my that:
C:\Users\My\Arduino\libraries\Arduino-Ethernet-Module-master\WebRemote_led_ctrl\WebRemote_led_ctrl.ino:11:25: fatal error: etherShield.h: No such file or directory
compilation terminated.
exit status 1
Fehler beim Kompilieren für das Board Arduino/Genuino Micro.
(deleted)
