Fatal error in script
Hey all,
extreme newby here but willy to learn.
having an issue with a script downloaded from GitHub (creates a LED matrix clock). GitHub - nygma2004/nrmetric: NRMeric - ESP Powered NeoPixel Display for Node Red
Get a " Fatal exception 0(IllegalInstructionCause):
epc1=0x402046b5, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000"
just after the device connects to WiFi.
Any help will be greatly appreciated.
Ian
Hi, @yanikdude
Welcome to the forum.
We will need to see your code and a link to the Github where you got the code.
What model Arduino are you using?
What version IDE are you using?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Help us help you.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Please post a schematic.
Please post an image of your project.
Please describe the problem better then you just did.
If you are using a 9V battery like this.
Don't.
Info about multi things
I2C scanner
What did the I2C scanner report?
Bread board power rail split
Serial Input basics.
The search box is a useful tool.
For instance using the words "9v battery" in the search box one could find lots of reasons why this may be a bad idea.
code merging
disclaimer
The events portrayed in this post are not all true. The names are not real names of real people and real organizations.
