Greetings,
I'm trying to install "JoystickTest" on a Seeedino Xiao, a 32U4 board. When it compiles I get the error message "fatal error: PluggableUSB.h: No such file or directory" See JoystickTest.ino below:
// Program used to test the USB Joystick object on the
// Arduino Leonardo or Arduino Micro.
// Matthew Heironimus
// 2015-03-28 - Original Version
// 2015-11-18 - Updated to use the new Joystick library
// written for Arduino IDE Version 1.6.6 and
// above.
// 2016-05-13 Updated to use new dynamic Joystick library
// that can be customized.
// 2022-03-29 Updated to work with version 2.1.0 of the
// Joystick library.
#include "Joystick.h"
// Create Joystick
Joystick_ Joystick;
// Set to true to test "Auto Send" mode or false to test "Manual Send" mode.
//const bool testAutoSendMode = true;
const bool testAutoSendMode = false;
const unsigned long gcCycleDelta = 1000;
const unsigned long gcAnalogDelta = 25;
const unsigned long gcButtonDelta = 500;
unsigned long gNextTime = 0;
unsigned int gCurrentStep = 0;
void testSingleButtonPush(unsigned int button)
if (button > 0)
Joystick.releaseButton(button - 1);
if (button < 32)
Joystick.pressButton(button);
void testMultiButtonPush(unsigned int currentStep)
for (int button = 0; button < 32; button++)
if ((currentStep == 0) || (currentStep == 2))
if ((button % 2) == 0)
} else if (currentStep != 2)
Joystick.releaseButton(button);
} // if ((currentStep == 0) || (currentStep == 2))
if ((currentStep == 1) || (currentStep == 2))
if ((button % 2) != 0)
} // if ((currentStep == 1) || (currentStep == 2))
if (currentStep == 3)
} // if (currentStep == 3)
} // for (int button = 0; button < 32; button++)
void testXYAxis(unsigned int currentStep)
int xAxis;
int yAxis;
if (currentStep < 256)
xAxis = currentStep - 127;
yAxis = -127;
Joystick.setXAxis(xAxis);
Joystick.setYAxis(yAxis);
else if (currentStep < 512)
yAxis = currentStep - 256 - 127;
else if (currentStep < 768)
xAxis = 128 - (currentStep - 512);
else if (currentStep < 1024)
yAxis = 128 - (currentStep - 768);
else if (currentStep < 1024 + 128)
xAxis = currentStep - 1024 - 127;
Joystick.setYAxis(xAxis);
void testZAxis(unsigned int currentStep)
int z;
if (currentStep < 128)
z = -currentStep;
else if (currentStep < 256 + 128)
z = currentStep - 128 - 127;
else if (currentStep < 256 + 128 + 127)
z = 127 - (currentStep - 383);
Joystick.setZAxis(z);
void testHatSwitch(unsigned int currentStep)
if (currentStep < 8)
Joystick.setHatSwitch(0, currentStep * 45);
else if (currentStep == 8)
Joystick.setHatSwitch(0, -1);
else if (currentStep < 17)
Joystick.setHatSwitch(1, (currentStep - 9) * 45);
else if (currentStep == 17)
Joystick.setHatSwitch(1, -1);
else if (currentStep == 18)
Joystick.setHatSwitch(0, 0);
Joystick.setHatSwitch(1, 0);
else if (currentStep < 27)
Joystick.setHatSwitch(0, (currentStep - 18) * 45);
Joystick.setHatSwitch(1, (8 - (currentStep - 18)) * 45);
else if (currentStep == 27)
void testThrottleRudder(unsigned int value)
Joystick.setThrottle(value);
Joystick.setRudder(value);
void testXYZAxisRotation(unsigned int degree)
Joystick.setRxAxis(degree);
Joystick.setRyAxis(degree);
Joystick.setRzAxis(degree * 2);
// Set Range Values
Joystick.setXAxisRange(-127, 127);
Joystick.setYAxisRange(-127, 127);
Joystick.setZAxisRange(-127, 127);
Joystick.setRxAxisRange(0, 360);
Joystick.setRyAxisRange(360, 0);
Joystick.setRzAxisRange(0, 720);
Joystick.setThrottleRange(0, 255);
Joystick.setRudderRange(255, 0);
if (testAutoSendMode)
Joystick.begin();
Joystick.begin(false);
pinMode(A0, INPUT_PULLUP);
pinMode(LED_BUILTIN, OUTPUT);
// System Disabled
if (digitalRead(A0) != 0)
// Turn indicator light off.
digitalWrite(LED_BUILTIN, 0);
return;
// Turn indicator light on.
digitalWrite(LED_BUILTIN, 1);
if (millis() >= gNextTime)
if (gCurrentStep < 33)
gNextTime = millis() + gcButtonDelta;
testSingleButtonPush(gCurrentStep);
else if (gCurrentStep < 37)
testMultiButtonPush(gCurrentStep - 33);
else if (gCurrentStep < (37 + 256))
gNextTime = millis() + gcAnalogDelta;
testThrottleRudder(gCurrentStep - 37);
else if (gCurrentStep < (37 + 256 + 1024 + 128))
testXYAxis(gCurrentStep - (37 + 256));
else if (gCurrentStep < (37 + 256 + 1024 + 128 + 510))
testZAxis(gCurrentStep - (37 + 256 + 1024 + 128));
else if (gCurrentStep < (37 + 256 + 1024 + 128 + 510 + 28))
testHatSwitch(gCurrentStep - (37 + 256 + 1024 + 128 + 510));
else if (gCurrentStep < (37 + 256 + 1024 + 128 + 510 + 28 + 360))
testXYZAxisRotation(gCurrentStep - (37 + 256 + 1024 + 128 + 510 + 28));
if (testAutoSendMode == false)
Joystick.sendState();
gCurrentStep++;
if (gCurrentStep == (37 + 256 + 1024 + 128 + 510 + 28 + 360))
gNextTime = millis() + gcCycleDelta;
gCurrentStep = 0;
When I install on an Adafruit FONA Feather, also a 32U4 board, it complies and upload with no issues.
I'm doing this on Kunubtu 22.10 with the latest updates as of this writing. Arduino IDE is version 2.1.0 Appimage.
"PlugableUSB" is part of the Arduino core as I understand it. Searched for "PluggableUSB.h" Found it located in the following locations:
~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/cores/arduino/USB/PluggableUSB.h
~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/PluggableUSB.h
~/.arduino15/packages/adafruit/hardware/samd/1.7.11/cores/arduino/USB/PluggableUSB.h
~/.arduino15/packages/arduino/hardware/samd/1.8.13/cores/arduino/api/PluggableUSB.h
~/.arduino15/packages/arduino/hardware/mbed_rp2040/4.0.2/cores/arduino/api/PluggableUSB.h
It should be using the first entry.
The full compile results for the Xiao:
FQBN: Seeeduino:samd:seeed_XIAO_m0
Using board 'seeed_XIAO_m0' from platform in folder: ~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4
Using core 'arduino' from platform in folder: ~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4
loading library from ~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/libraries/Adafruit_TinyUSB_Arduino: invalid library: no header files found
loading library from ~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/libraries/Seeed_Arduino_FreeRTOS: invalid library: no header files found
loading library from ~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/libraries/Seeed_Arduino_LCD: invalid library: no header files found
Detecting libraries used...
~/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"JoystickTest.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Seeed\"" "-DUSB_PRODUCT=\"Seeed XIAO M0\"" -I~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/libraries/Adafruit_TinyUSB_Arduino/src/arduino -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Seeed\"" "-DUSB_PRODUCT=\"Seeed XIAO M0\"" -I~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/libraries/Adafruit_TinyUSB_Arduino/src/arduino -I~/.arduino15/packages/Seeeduino/tools/CMSIS/5.7.0/CMSIS/Core/Include/ -I~/.arduino15/packages/Seeeduino/tools/CMSIS/5.7.0/CMSIS/DSP/Include/ -I~/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -I~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/cores/arduino -I~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/variants/XIAO_m0 /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/sketch/JoystickTest.ino.cpp -o /dev/null
Alternatives for Joystick.h: [Joystick@2.1.1]
ResolveLibrary(Joystick.h)
-> candidates: [Joystick@2.1.1]
~/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"JoystickTest.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Seeed\"" "-DUSB_PRODUCT=\"Seeed XIAO M0\"" -I~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/libraries/Adafruit_TinyUSB_Arduino/src/arduino -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Seeed\"" "-DUSB_PRODUCT=\"Seeed XIAO M0\"" -I~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/libraries/Adafruit_TinyUSB_Arduino/src/arduino -I~/.arduino15/packages/Seeeduino/tools/CMSIS/5.7.0/CMSIS/Core/Include/ -I~/.arduino15/packages/Seeeduino/tools/CMSIS/5.7.0/CMSIS/DSP/Include/ -I~/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -I~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/cores/arduino -I~/.arduino15/packages/Seeeduino/hardware/samd/1.8.4/variants/XIAO_m0 -I~/Arduino/libraries/Joystick2/src /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/sketch/JoystickTest.ino.cpp -o /dev/null
In file included from ~/Arduino/libraries/Joystick2/src/Joystick.h:24:0,
from /tmp/.arduinoIDE-unsaved2023428-24193-4fnhrp.hqowt/JoystickTest/JoystickTest.ino:15:
~/Arduino/libraries/Joystick2/src/DynamicHID/DynamicHID.h:37:12: fatal error: PluggableUSB.h: No such file or directory
#include "PluggableUSB.h"
compilation terminated.
Alternatives for PluggableUSB.h: []
ResolveLibrary(PluggableUSB.h)
-> candidates: []
Using library Joystick at version 2.1.1 in folder: ~/Arduino/libraries/Joystick2
exit status 1
Compilation error: exit status 1
The full compile results for the Feather:
FQBN: adafruit:avr:feather32u4
Using board 'feather32u4' from platform in folder: ~/.arduino15/packages/adafruit/hardware/avr/1.4.15
Using core 'arduino' from platform in folder: ~/.arduino15/packages/arduino/hardware/avr/1.8.6
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_FEATHER32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x800C "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather 32u4\"" -I~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I~/.arduino15/packages/adafruit/hardware/avr/1.4.15/variants/feather32u4 /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/sketch/JoystickTest.ino.cpp -o /dev/null
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_FEATHER32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x800C "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather 32u4\"" -I~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I~/.arduino15/packages/adafruit/hardware/avr/1.4.15/variants/feather32u4 -I~/Arduino/libraries/Joystick2/src /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/sketch/JoystickTest.ino.cpp -o /dev/null
Using cached library dependencies for file: ~/Arduino/libraries/Joystick2/src/DynamicHID/DynamicHID.cpp
Using cached library dependencies for file: ~/Arduino/libraries/Joystick2/src/Joystick.cpp
Generating function prototypes...
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_FEATHER32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x800C "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather 32u4\"" -I~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I~/.arduino15/packages/adafruit/hardware/avr/1.4.15/variants/feather32u4 -I~/Arduino/libraries/Joystick2/src /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/sketch/JoystickTest.ino.cpp -o /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/preproc/ctags_target_for_gcc_minus_e.cpp
~/.arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_FEATHER32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x800C "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather 32u4\"" -I~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I~/.arduino15/packages/adafruit/hardware/avr/1.4.15/variants/feather32u4 -I~/Arduino/libraries/Joystick2/src /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/sketch/JoystickTest.ino.cpp -o /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/sketch/JoystickTest.ino.cpp.o
Compiling libraries...
Compiling library "Joystick"
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_FEATHER32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x800C "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather 32u4\"" -I~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I~/.arduino15/packages/adafruit/hardware/avr/1.4.15/variants/feather32u4 -I~/Arduino/libraries/Joystick2/src ~/Arduino/libraries/Joystick2/src/Joystick.cpp -o /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/libraries/Joystick2/Joystick.cpp.o
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=8000000L -DARDUINO=10607 -DARDUINO_AVR_FEATHER32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x239A -DUSB_PID=0x800C "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather 32u4\"" -I~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I~/.arduino15/packages/adafruit/hardware/avr/1.4.15/variants/feather32u4 -I~/Arduino/libraries/Joystick2/src ~/Arduino/libraries/Joystick2/src/DynamicHID/DynamicHID.cpp -o /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/libraries/Joystick2/DynamicHID/DynamicHID.cpp.o
Compiling core...
Using precompiled core: /tmp/arduino/cores/adafruit_avr_feather32u4_8eeaa37527416ee2d1a9c4d41640ce27/core.a
Linking everything together...
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/JoystickTest.ino.elf /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/sketch/JoystickTest.ino.cpp.o /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/libraries/Joystick2/DynamicHID/DynamicHID.cpp.o /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/libraries/Joystick2/Joystick.cpp.o /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/../../cores/adafruit_avr_feather32u4_8eeaa37527416ee2d1a9c4d41640ce27/core.a -L/tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF -lm
~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/USBCore.cpp: In function 'USB_Recv.constprop':
~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/USBCore.cpp:255:9: warning: 'c' may be used uninitialized in this function [-Wmaybe-uninitialized]
return c;
~/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/USBCore.cpp:252:5: note: 'c' was declared here
u8 c;
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/JoystickTest.ino.elf /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/JoystickTest.ino.eep
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/JoystickTest.ino.elf /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/JoystickTest.ino.hex
~/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /tmp/arduino/sketches/B276041422C7C70A81C7378E16FFBFCF/JoystickTest.ino.elf
Sketch uses 10054 bytes (35%) of program storage space. Maximum is 28672 bytes.
Global variables use 348 bytes of dynamic memory.
I believe it is a matter of telling the compiler where to find "PluggableUSB.h" for the Xiao. How do I do this? If it is something else please let me know.
Thanks!
Randy
