fatal error: sdkconfig.h: No such file or directory
I am facing this error when trying to compile my code (fatal error: sdkconfig.h: No such file or directory). for a BLuno board. Anyone have an idea why this error keeps displaying
This is the code
#include <WiFiEsp.h>
#include <WiFiEspClient.h>
#include <WiFiEspServer.h>
#include <WiFiEspUdp.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include <HID.h>
#include <Mouse.h>
#include <ArduinoBLE.h>
#include <BLEAttribute.h>
#include <BLECharacteristic.h>
#include <BLEDescriptor.h>
#include <BLEDevice.h>
#include <BLEProperty.h>
#include <BLEService.h>
#include <BLETypedCharacteristic.h>
#include <BLETypedCharacteristics.h>
#include <BLEUuid.h>
 * BLE_WaterMonitor.ino
 * Derived from WaterMonitor.ino by Jason(jason.ling@dfrobot.com) 2017-04-06
 * Derived from ardiuno_sketch_for_esp32.ino by Jeff L 2018-05-14
 * Description:
 * monitor water quality including ph, temperature, dissolved oxygen, ec and orp,etc.
 * Software Environment: Arduino IDE 1.8.2
 * Software download link: https://www.arduino.cc/en/Main/Software
 * Install the library file:
 * Copy the files from the github repository folder libraries to the libraries
 * in the Arduino IDE 1.8.2 installation directory
 * Hardware platform : Arduino with BluetoothLE (BLE)
 * Sensor pin:
 * EC  : A1
 * PH  : A2
 * ORP : A3
 * RTC : I2C
 * DO  : Serial port Rx(0),Tx(1)
 * GravityDO:A4
 * temperature:D5
 * SD card attached to SPI bus as follows:
 * Mega:  MOSI - pin 51, MISO - pin 50, CLK - pin 52, CS - pin 53
 * and pin #53 (SS) must be an output
 * M0:   Onboard SPI pin,CS - pin 4 (CS pin can be changed)
 * author  :  Chris Ward https://www.professorcad.co.uk
 * version :  V1.0
 * date    :  2018-12-17
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "GravitySensorHub.h"
#include "GravityRtc.h"
#include "OneWire.h"
#include "SdService.h"
#include "Debug.h"
#include <SoftwareSerial.h>
#include "dht.h"
#include <LiquidCrystal.h>
//// BluetoothLE
//#include <BLEDevice.h>
//#include <BLEServer.h>
//#include <BLEUtils.h>
//#include <BLE2902.h>
BLEServer *pServer = NULL;
BLECharacteristic * pTxCharacteristic;
bool deviceConnected = false;
bool oldDeviceConnected = false;
// To generate UUIDs: https://www.uuidgenerator.net
#define SERVICE_UUID         "e8a4395S-892c-4333-bd5e-f7c70d81aece"
#define CHARACTERISTIC_UUID  "e8a4395C-892c-4333-bd5e-f7c70d81aece"
class MyServerCallbacks: public BLEServerCallbacks {
    void onConnect(BLEServer* pServer) {
      deviceConnected = true;
    void onDisconnect(BLEServer* pServer) {
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 8, rw = 7, en = 6, d4 = 10, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, rw, en, d4, d5, d6, d7);
dht DHT;
#define DHT11_PIN 9
// clock module
GravityRtc rtc;
// sensor monitor
GravitySensorHub sensorHub;
SdService sdService = SdService(sensorHub.sensors);
                     rtc.setup();
               sensorHub.setup();
               sdService.setup();
                     lcd.begin(16, 4);
                     lcd.print("Temp");
               // Create the BLE Server
               pServer = BLEDevice::createServer();
               pServer->setCallbacks(new MyServerCallbacks());
               // Create the BLE Service
               BLEService *pService = pServer->createService(SERVICE_UUID);
               // Create a BLE Characteristic
               pTxCharacteristic = pService->createCharacteristic(CHARACTERISTIC_UUID, BLECharacteristic::PROPERTY_NOTIFY);
               pTxCharacteristic->addDescriptor(new BLE2902());
               // Start the service
               pService->start();
               // Start advertising
               pServer->getAdvertising()->start();
// function name: sensorHub.getValueBySensorNumber (0)
// Function Description: Get the sensor's values. The parameters represent the acquisition of different sensor data
// Parameters: 0 ph value
// Parameters: 1 temperature value
// Parameters: 2 Dissolved Oxygen
// Parameters: 3 Conductivity
// Parameters: 4 Redox potential
// return value: returns a double type of data
unsigned long updateTime = 0;
String          sAllVals = "";
String                sD = "|";
String               sPH = "";
String            sWTemp = "";
String               sDo = "";
String               sEc = "";
String              sOrp = "";
String             sTamb = "";
String               sRH = "";
    rtc.update();
    sensorHub.update();
    sdService.update();
    if(millis() - updateTime > 5000)
                   updateTime = millis();
                      int chk = DHT.read11(DHT11_PIN);
               // BLE TO APP
                    sPH = String(sensorHub.getValueBySensorNumber(0), 2);
                 sWTemp = String(sensorHub.getValueBySensorNumber(1), 2);
                    sDo = String(sensorHub.getValueBySensorNumber(2), 2);
                    sEc = String(sensorHub.getValueBySensorNumber(3), 2);
                   sOrp = String(sensorHub.getValueBySensorNumber(4), 2);
                  sTamb = String(DHT.temperature, 2);
                    sRH = String(DHT.humidity, 2);
               sAllVals = sPH + sD + sWTemp + sD + sDo + sD + sEc + sD + sOrp + sD + sTamb + sD + sRH + "\n"
               pTxCharacteristic->setValue(sAllVals);
               pTxCharacteristic->notify(); // Send to App
               // LCD DISPLAY
               lcd.setCursor(0,0);
               lcd.print("Temp: ");
               lcd.print(DHT.temperature);
               lcd.print("deg C");
               lcd.setCursor(0,1);
               lcd.print("Humd: ");
               lcd.print(DHT.humidity);
               lcd.print("%");
               lcd.setCursor(0,2);
               lcd.print("pH: ");
               lcd.print(sensorHub.getValueBySensorNumber(0));
               lcd.setCursor(0,3);
               lcd.print("EC: ");
               lcd.print(sensorHub.getValueBySensorNumber(3));
               lcd.print("mS/CM");
Take the file "sdkconfig.h" from here and copy it into your sketch folder.
this is what I did but didnt work also
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here using code tags (</> button on the forum toolbar).
Sorry, you also need to "include" this file in your sketch, by adding in the first lines the following:
#include "sdkconfig.h"
