I am work on an RTC with arduino uno and LCDKeypad shield, when i compile the code it gives this error
< fatal error: LCDKeypad.h: No such file or directory
compilation terminated.
Error compiling.>
This is the code
<< #include <LiquidCrystal.h>
#include "Keypad.h"
#include "Wire.h"
#define DS3231_I2C_ADDRESS 0x68
#define DAYS 0
#define HOURS 1
#define MINUTES 2
#define SECONDS 3
// The LCD screen
LCDKeypad lcd;
// The time model
unsigned int days = 0;
unsigned int hours = 0;
unsigned int minutes = 0;
unsigned int seconds = 0;
unsigned int setting = 0;
// Set up the LCD's number of columns and rows:
lcd.begin(16,2);
// Set the cursor at the begining of the first row
lcd.setCursor(0,0);
// Print a text in the first row
lcd.print("Setting: Days ");
// Increase the time model by one second
incTime();
// Print the time on the LCD
printTime();
// Listen for buttons for 1 second
buttonListen();
void buttonListen() {
// Read the buttons five times in a second
for (int i = 0; i < 5; i++) {
// Read the buttons value
int button = lcd.button();
switch (button) {
// Right button was pushed
case KEYPAD_RIGHT:
setting++;
// Left button was pushed
case KEYPAD_LEFT:
setting--;
// Up button was pushed
case KEYPAD_UP:
switch (setting) {
case DAYS:
days++;
case HOURS:
hours++;
case MINUTES:
minutes++;
case SECONDS:
seconds++;
// Down button was pushed
case KEYPAD_DOWN:
switch (setting) {
case DAYS:
days--;
if (days == -1) days = 99;
case HOURS:
hours--;
if (hours == -1) hours = 23;
case MINUTES:
minutes--;
if (minutes == -1) minutes = 59;
case SECONDS:
seconds--;
if (seconds == -1) seconds = 59;
setting %= 4;
printSetting();
days %= 100;
hours %= 24;
minutes %= 60;
seconds %= 60;
printTime();
// Wait one fifth of a second to complete
while(millis() % 200 != 0);
// Print the current setting
void printSetting() {
lcd.setCursor(9,0);
switch (setting) {
case DAYS:
lcd.print("Days ");
case HOURS:
lcd.print("Hours ");
case MINUTES:
lcd.print("Minutes");
case SECONDS:
lcd.print("Seconds");
void incTime() {
// Increase seconds
seconds++;
if (seconds == 60) {
// Reset seconds
seconds = 0;
// Increase minutes
minutes++;
if (minutes == 60) {
// Reset minutes
minutes = 0;
// Increase hours
hours++;
if (hours == 24) {
// Reset hours
hours = 0;
// Increase days
days++;
void printTime() {
// Set the cursor at the begining of the second row
lcd.setCursor(0,1);
char time[17];
sprintf(time, "%02i days %02i:%02i:%02i", days, hours, minutes, seconds);
lcd.print(time);
