Fatal exception (0): on ESP8266 with arduino Due
I am working with ESP8266 on arduino due, i shorted the serial and using serial0 for communicating with the module, it was working fine for few days suddenly it showed up this error at a very different baud rate-74880
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 612, room 16
tail 4
chksum 0x12
⸮⸮&⸮V⸮⸮⸮bb⸮⸮⸮788, room 4
tail 0
chksum 0x50
load 0x3ffe8314, len 264, room 8
tail 0
chksum 0x4a
csum 0x4a
2nd boot version : 1.1
SP⸮⸮j!⸮5
SPI Mode : QIO
SPI Flash Size : 4Mbit
jump to run user1
epc1=0x40211558, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
the first part until "jump to run user1" is always there.
what application should run in esp8266? AT firmware? or your sketch?
how do you power the esp8266?
Shravan_Anand_K:
I am working with ESP8266 on arduino due....
What does that mean ?
Shravan_Anand_K:
i connected the tx of wifi module to tx0 of arduino and rx to rxo, and reset pin of arduino due to GND, so that i can directly communicate with wifi module using COM port, it was working fine at 9600 baud i was able to send AT commands on serial monitor buT suddenly it crashed and sending the above exception at a different baud rate.
i connected VCC to 3.3v, CH_PD to 53 pin of arduino DUE
Shravan_Anand_K:
once you joined an AP it uses WiFi and starts the connection at boot. but the powering fails to provide enough current and the esp8226 crashes
