Faulhaber Encoder Question
I was using a Faulhaber motor with magnetic encoder. I was wondering if anyone could give me guidance on how to integrate this with an Arduino Uno, like how do get readings from the encoder.
Here are the Spec Sheets: http://www.robotstorehk.com/soccer/doc/ie2-512.pdf
Thank You =(
Connect VDD and GND of the Encoder to the Arduino 5V and GND.
Connect ChannelA & ChannelB to two input pins on the arduino.
Try testing this with a sketch meant for an encoder knob. Simple.
Now, to control the motor with feedback from the encoder, you need to look into PID control, which isn't easy.
// Per.
Can someone post a sample code for a magnetic rotary encoder.
Would I place channel A & B into the digital, or analogue pins. and why are there two channels? don't you just need one? :~
sexybeast:
The outputs behave just exactly like an encoder knob. You connect these to any pins on the Arduino (except the pin0 and 1) and read them as digital pins.
http://playground.arduino.cc/Main/RotaryEncoders#.Uz3gIOeSwa4
// Per.
Thanks so much 20!! :roll_eyes: :slight_smile:
