i have three sainsmart products: Due / CTE v1.04 / TFT LCD 3.2" (ebay product*)
the touch doesn't give coordinates, it only gives zeros and at times it blocks and sends no more while the program keeps running
Here's the program that i am using:
#include <UTFT.h>
#include <UTouch.h>
// Initialize display
// Set the pins to the correct ones for your development board
// Standard Arduino Uno/2009 Shield : <display model>,19,18,17,16
// Standard Arduino Mega/Due shield : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Due : <display model>,25,26,27,28
// Teensy 3.x TFT Test Board : <display model>,23,22, 3, 4
// ElecHouse TFT LCD/SD Shield for Arduino Due : <display model>,22,23,31,33
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(ITDB32S,25,26,27,28);
// Initialize touchscreen
// Standard Arduino Uno/2009 Shield : 15,10,14, 9, 8
// Standard Arduino Mega/Due shield : 6, 5, 4, 3, 2
// CTE TFT LCD/SD Shield for Arduino Due : 6, 5, 4, 3, 2
// Teensy 3.x TFT Test Board : 26,31,27,28,29
// ElecHouse TFT LCD/SD Shield for Arduino Due : 25,26,27,29,30
UTouch myTouch( 6, 5, 4, 3, 2);
// Declare which fonts we will be using
extern uint8_t SmallFont[];
#define TFT_WIDTH 320
#define TFT_HEIGHT 240
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.setFont(SmallFont);
myTouch.InitTouch(PORTRAIT);
// pinMode(3,INPUT_PULLUP);
int x,y,iteration=0;
String toDraw;
String toDraw2;
myGLCD.setColor(VGA_BLACK);
myGLCD.setBackColor(VGA_BLACK);
myGLCD.print(toDraw2,CENTER,TFT_HEIGHT/2-6+12);
myGLCD.setColor(VGA_WHITE);
myGLCD.setBackColor(VGA_RED);
toDraw2=String(millis()/1000.0,1);
while (myTouch.dataAvailable() == true){
myTouch.calibrateRead();
x=myTouch.TP_X;
y=myTouch.TP_Y;
toDraw=String(x)+","+String(y);
myGLCD.print(toDraw,CENTER,TFT_HEIGHT/2-6);
The TFT LCD is fully functional and i think so is the Due. I also have set the 2x 3.3V jumpers in the shield and the jumper concerning the SD Card SS Pin (53). The two 5V are not jumped. A friend of mine also tested TDOUT with an oscilloscope and it does send data but the level stays low, not even 0.5V.
I believe the touch is faulty. Are there any other tests i can run?
IMAGES:
- NOT SENDing
- SENDing with PULLUP
- SENDing
- here are some images of the shield
