Fauxmo Maximum Number of Devices
Using current version of Fauxmo Library on ESP8266 (ESP-12)
With Arduino v1.8.8
Having good results.
But....
Can only add three devices.
Alexa discovers these OK.
But if I remove these devices from Alexa, then add FOUR devices with Fauxmo, then Alexa won't discover ANY of the four devices.
If I go back and change sketch to have Fauxmo add THREE devices (as above) then Alexa will once again discover the three devices OK.
Suggestions please ?
Need to add more devices.
Bob W
You failed to post a link to the library you are using. You wouldn't like my suggestion.
https://bitbucket.org/xoseperez/fauxmoesp
Link to Library above.
Confirming here - you can only add 3 devices using FauxmoESP library. If you add more than 3, none of the devices show up in discovery from Alexa. Seems like this is a limitation imposed by Alexa on the number of devices linked to an IP address.
