FE1.1s USB hub crystal's capacitance
I'm wondering if anyone has data sheet showing how to choose crystal for FE1.1s USB hub IC. The only one I found was on adafruit's website and has no mention of what crystal capacitance should be.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi1w7Wf58ztAhWoo1kKHTssCAsQFjAAegQIAhAC&url=https%3A%2F%2Fcdn-shop.adafruit.com%2Fproduct-files%2F2991%2FFE1.1s%2BData%2BSheet%2B(Rev.%2B1.0).pdf&usg=AOvVaw1FMYSXfWJ1gzU0XU3nWb9V
I've dealt with issues of crystal capacitance on the MAX3421E USB host IC so I'm wary of choosing a random 12MHz crystal. I have a number of them with different capacitance values and not all of them seem to work with MAX3421E.
Choose the crystal, and use it's datasheet to choose the capacitors.
I found a more recent data sheet. 16-20pF load capacitance. ESR is not listed. The "load" capacitors or coupling capacitors are integrated. I'm very tempted to just try it. The alternative I found, TUSB2046B is a mess. Everything is external, dozens of resistors and caps.
