I am a newbie on Arduino but I already did the tutorials, so the basics are there, hopefully.
I have a couple of push buttons that execute code, like rotate servos, change LEDs, ...
Now I want to join them in one single project.
Before starting I would like to know the better way to "disable" a push button while the code is being executed.
I do not want to be possible to press again the same button while the code for that button is being executed, but I want to be able to press another button and execute another code.
xl97:
Just dont check the state (change) of that particular button then?
But I have to to be constantly checking for a button press to execute the code.
Sorry, it may be trivial but I do not understand.
UKHeliBob:
Make reading the button state dependant on a boolean. Change the state of the boolean to enable/disable reading the state of the button.
So, for example, in the code of the button press I insert an if statement checking "actionstarted == False" and then inside I update "actionstarted = True". Then comes the stuff to be executed and in the end of the code I update again "actionstarted = False". Similar to debouncing using millis()
FilipeAlmeida:
Yes, that's the idea.
And when you're at it, look into the concept of "finite state machine" as that's what you're doing here. You put your machine into a different state based on button press and code execution stage.
