Feasability of UNO to upgrade firmware of Sonmicro SM130
I'm currently experimenting with RFID technologies, and have been using the Sonmicro SM130 (RFID Module - SM130 MIFARE® (13.56 MHz) - SEN-10126 - SparkFun Electronics) as an RFID controller with the Arduino UNO.
Everything's going well, but I've at a point where an alternative firmware on the SM130 would be preferable. (I'm looking to have different logic for anti-collision of tag reads.) One of my references led to the following page (http://www.mcqn.net/mcfilter/archives/computers/upgrading_the_firmware_on_the_sm130_rfid_module.html), which suggests to use a modified Arduino (sans-processor) to act as a FTDI connection between computer and RFID controller.
Basically, the suggestion on the site was:
  • Remove the ATMEGA processor from the Arduino
  • Hook the RFID controller to RX, TX, 5v, GND.
...and once connected to the computer, it would act as a USB-Serial passthrough and the Sonmicro firmware updater should work without complaint.
The catch is that they are using the Arduino Duemilanove, which comes with a built in FTDI chip. I'm using the UNO with the ATmega8U2, and I suspect it's not going to work. (At work now, cannot try until I get back to workshop later tonight.) I don't understand the differences between the FTDI chip and the ATmega8U2, but I see various references in programming guides about how the UNO requires different steps for programming external chips. (i.e. requiring a bridge between reset and ground for some tasks).
I've been going around the forums, wiki, and various corners of the internet... and I'm getting dizzy with what I find. Can someone help confirm whether the above instructions would work with the UNO, or if not, what alternatives I can attempt?
For this project you can use an UNO as well. The only difference is the USB driver used on the PC but the serial connection used for this project delivers exactly the same.
Easier to use would be an adapter like the USB2Serial Light (also from Arduino), FTDI cable, Foca or anything like this because you don't have to dismount the processor from your UNO board (mounting it again is quite error prone).
