Feasibility details
I'm trying to create a robot that will be able to be controlled wirelessly. I've seen many similar projects, but haven't found one with exactly the same setup I'm trying. Just want to get a sanity check to see if any of the communications links or methods are not doable.
Basic blocks:
Laptop w/ wifi --> VB.net form -->TCP --> Xbee S6B (wifi) --> serial data --> Arduino (uno or mega) --> Arduino Motor shield --> 2x dc motors
Details:
  1. Control (user) interface --> VB.net form with buttons
  2. So buttons or keyboard can generate a single character (eg 'w' for forward) When the key or button is released, a second character is sent to engage the motor braking - completed this part today.
  3. Now I think I can use TCP sockets to send the ascii character to the XBee (haven't worked out all the code yet, but working on it). ADDED: Laptop (Windows 7) is connected to the XBee (configured as a SoftAP).
  4. The XBee then sends the ascii character to the Arduino through the serial in/out (pin0/1).
  5. Then the arduino interprets the ascii character and sends 'direction, speed (PWM) and braking' commands to the motorshield.
  6. Then motorshield controls the motors to move the bot.
I'm fairly sure I understand 1, 2, 5 and 6 pretty well. However 3 and 4 are not quite there. Am I thinking these two steps correctly or am I missing a link somewhere.
Thanks for the advice.
Joe B
EDITED to add the wireless connection is using the laptop to connect to the XBee (configured as a Soft AP)
