Hello. I wasn't sure to post this on the project guidance or here, because it's a mix of the two topics...
I have a project which uses 3 4067 for analog inputs, 24 potentiometers and 8 on-off-on swtiches. And a 4067 for digital inputs. It's working fine. But i want to expand it to:
5 4067, 48 10k potentiometers and 16 on-off-on keys. Is there anything I should worry about? I'm pushing the arduino to the limits? Am i safe
I had problems with the analogreads getting mixed up but fixed it with two consecutive analogreads as suggested.
Also which would be a good power supply to power it? With this set of 24 pots, and 3 74HC595, some normal leds(only 3 HIGH at the same time) with an 16x2 blue backlight lcd display, sometimes I see that the backlight flickers a bit, I read this is because i'm on the limit of the USB current. So, 1A would be good?
I'll try it eventually, but just wondering if it's good, I searched and I didn't find projects with this number of potentiometers.
thanks
