I'm new in this forum and I need some advise about this new project.
I am a developing an e-textile by weaving conductive yarns with other non-conductive (traditional) yarns. The idea is to touch the conductive parts of the pattern and switch on and off some LED strip.
Being a e-textile project, the obvious choice is Lilypad/Flora, but I'm not sure if it is the best fit, since this is not a wearable project. I actually don't want to use any batteries, just regular current, it is meant to work as a lamp, so I also need to turn on a strip of at least 30cm.
Yes you can make a touch sensor even one that has multiple selections by weaving your wire in a 3.3v - input# - 3.3v - input# and so on like that then use a 100k ohm pull down on the the input#s feed that to a transistor and use the output of it as the input to the arduino. You can have as many as you have inputs and since its gonna be in lamp id use and UNO for this. Also use transistors or MOSFETs to drive the leds. There are web pages that will calculate what resistor you need for the LEDs.
Yes, getting 1/2 watt is some what silly as there is no way you are going to exceed the power dissipation.
Watts = Volts * Amps.
So for 1M across 5V the amps you have is 5uA that means the resistor will dissipate:-
0.000025 watts so a 0.25 resistor is safe by a factor of 10,000 times so I think you are save enough. A 1/2 Watt would be safe by 20,000 times, not worth it is it?
Yes that FET will work with the logic levels out of an arduino.
Hello!
I got a 1000mA DC adapter with a max of 12v output, and it works fine with a short LED strip, however, I'd like to know what is the maximum of LEDs I can turn on.
Will it work for a 150 diode strip or is it too much?
