Hi. I'm planning something and would like to know from experts if this is even possible.
Imagem to place a Lidar or Ultrasound meter about 5 or 10cm from the floor pointing down. So this sensor would start to open an arc to front giving the the distance from the floor. The initial distance and this distance are two sides of a triagle, so I know the 3rd side (the one parallels to to the floor, that is the distance from the device base to where the sensor is pointing now).
I would need a precision of 1cm tops and a base distance of about 20cm to 100cm.
The material of the surfaces would be mostly wood and cardboard.
My doubts are:
1- One of this sensors would work ok in this diagonal condition? There is a better one?
2- If so, I need the arc to open to front and to 1 side. There is a best fit servo here?
3- I'll use Node.js to code it up and transfer the results over bluetooth or wifi, probably to an Android app. There is a best fit board here?
(Now I'm not sure if a Yum board would suffice, or couple the board with a Rpi, or maybe cable up it to the Smartphone and let the app control the board would be better.)
Thank you.
