feasibility question: turning dc motor to servo?
There's nothing stopping you from putting a feedback loop on your motor control, and it would solve this problem completely.
Essentially, rather than switch the motor on to move it and switching it off when it reaches the required position, you would specify the desired motor position and continually compare the current position with the desired position and apply power to the motor to move it to the desired position. You could hard-code this feedback quite easily using a simple proportional algorithm, but if you have moving assemblies involved with inertia to deal with then a PID control algorithm would be ideal since it would take care of all of that for you. There is already a PID library for the Arduino. The error signal would be the difference between desired and actual position and the output would be PWM duty cycle and direction.
