feasibility question: turning dc motor to servo?
Hi, just wanted to add some comment not directly connected to the issue.
i have been working with an industrial robotic arm for some time now. The industrial solution for your issue is by having a high ratio gear motor with high friction. the added friction coupled with a high gear ratio (1:100) improves the precision and reduces the gravity pull effect. in addition you need a high freq control loop to keep the arm well position and in high control. additionally it is common to add a low voltage break. meaning that if your power is cut out your breaks jump in.
hop it helped.
