Feasibility question
I just came across this site and the Arduino device. Sounds like it might be the perfect answer to what u have been looking for for a long time
My question is this:
I have a project that's requires 9 white LEDs to illuminate. The design criteria is this:
All nine light up simultaneously. All nine go out Each of the nine then illuminate in random fashion ( no specific sequence) After the random sequence, all nine illuminate simultaneously and then go out. The sequence repeats.
If the next sequence woul not match the first sequence, that woul be even better
Is this possible to achieve with this device? Note that I am a complete novice ate programming; this is why I am asking if it is even possible.
Thanks in advance. I would appreciate any input I can get. Thanks again.
Yes that is possible. I would start by learning the Blink Without Delay example. http://arduino.cc/en/Tutorial/BlinkWithoutDelay and learn how to manipulate 1 LED.
Once you have that done try adding another LED.
Since you didn’t specify any time between turning on and turning off I did not put any delays in. This will cause the LEDs turn on and off so frequently they appear a fairly uniform grey. You will have to insert delays if you want to be able to see the actual sequence.
// I have a project that's requires 9 white LEDs to illuminate.
const int LEDcount = 9;
const int LEDpins[LEDcount] = {2, 3, 4, 5, 6, 7, 8, 9, 10};  // Data pins connected to white LEDs and current limiting resistors
  for (int i = 0; i < LEDcount; i++)
    pinMode(LEDpins[i], OUTPUT);
// The design criteria is this:
  // All nine light up simultaneously.
    digitalWrite(LEDpins[i], HIGH);
  // All nine go out
    digitalWrite(LEDpins[i], LOW);
  // Each of the nine then illuminate in random fashion ( no specific sequence)
  randomSequence();
  // After the random sequence, all nine illuminate simultaneously and then go out.
  // The sequence repeats.
void randomSequence() {
  int  sequence[LEDcount];
  // Fill the sequence
    sequence[i] = LEDpins[i];
  // Shuffle the sequence by swapping each with a random index
  for (int i = 0; i < LEDcount; i++) {
    int index = random(LEDcount);  // Pick a number from 0 to LEDcount-1
    // Swap the two entries
    int temp = sequence[i];
    sequence[i] = sequence[index];
    sequence[index] = temp;
  // Light up in random sequence
    digitalWrite(sequence[i], HIGH);
The demo several things at a time is an extended example pf BWoD with 3 LEDS.
...R
Thank you Mr. John for the really quick response.
Apologies for not specifying the delay rates. My bad.
The initial illumination (all nine) should last 5 seconds
All nine going out duration should last 2.5 seconds
The blink of each LED should last 1.5 seconds
After the random sequence, the final re-illumination (all 9) should last 5 seconds
Then repeat
Thanks for your help!!!! I really appreciate it.
