Hello Everyone! This is my first post and I don't have a lot of experience posting on forums in general, so go easy on me.
I've referenced so many other topics that just touch the subject, but I can't seem to put the pieces of the puzzle together to form the big picture.
Question...
I'm having some trouble figuring out what needs to be done to use the only hardware serial port on the UNO in a sketch, when it's already in use with the USB cable connected to the computer. Can I download the sketch as I normally would, while using Serial in my code, instead of an instance of SoftwareSerial (as shown in the example for the Adafruit_Soundboard.h) while pins 0 and 1 are disconnected from the sound board, and then just disconnect the USB, connect pins 0 and 1 to the sound board, and connect an external power source? Or possibly do I need to find an alternative way to download the sketch?
Why...
Using SDFat.h, SoftwareSerial.h, and Adafruit_Soundboard.h has used up quite a bit of dynamic memory (85%). I was hoping to get rid of using SoftwareSerial.h by using the existing hardware serial. I believe it would also solve an issue I have with servo's jerking every time the sound board is activated. I believe the SoftwareSerial.h library is hosing up the interrupts. Could also be a power thing, but I need to test more.
Project Background...
My project involves an Arduino UNO, Adafruit Micro-SD Breakout Board, and Adafruit Mini Sound Fx Board. The SD card holds text files with commands for various different outputs, such as a LED, a Servo, or a sound from the fx board. The command contains an action and a duration. When the duration has lapsed, the next command for that pin is fetched from the SD card. I refer to the text files as scripts, which are played at random, with random delays between scripts. My hope is to develop a generic controller for animatronic props.
Thanks to all who took the time to review this topic and even more thanks to those who take the time answer!
BAR
