Hi folks,
I'm trying to use the CAN1 bus and NeoPXL8 concurrently on my M4 CAN setup. Eventually, I plan to use the CAN commands to command led animations. I believe I'm hitting a conflict between the two libraries (ACANFD_FeatherM4CAN.h and Adafruit_NeoPXL8.h). Individually they work fine. I can receive CAN commands with the first, and light up leds with the other.
But the moment I call them in the same file, the M4 freezes up. It's serial communication stops and it does neither of the functions. Is there any setting that I'm forgetting?
Code below:
#define CAN0_MESSAGE_RAM_SIZE (0)
#define CAN1_MESSAGE_RAM_SIZE (1728)
#include <ACANFD_FeatherM4CAN.h>
#define NUM_LEDS 10 // NeoPixels PER STRAND, total number is 8X this!
#define COLOR_ORDER NEO_WRGB // NeoPixel color format (see Adafruit_NeoPixel)
#include <Adafruit_NeoPXL8.h>
void setup () {
//--- Note: for compatibility with releases 1.x, insert ACANFD_FeatherM4CAN_Settings::CLOCK_48MHz
// as first argument, 48 MHz clock was the only available clock in release 1.x
ACANFD_FeatherM4CAN_Settings settings (ACANFD_FeatherM4CAN_Settings::CLOCK_48MHz, 500 * 1000, DataBitRateFactor::x1) ;
pinMode(PIN_CAN_STANDBY, OUTPUT);
digitalWrite(PIN_CAN_STANDBY, false); // turn off STANDBY
pinMode(PIN_CAN_BOOSTEN, OUTPUT);
digitalWrite(PIN_CAN_BOOSTEN, true); // turn on booster
int8_t pins[8] = { 13, 12, 11, 10, SCK, 5, 9, 6 };
Adafruit_NeoPXL8 leds(NUM_LEDS, pins, COLOR_ORDER);
while (!Serial) {
delay (50) ;
digitalWrite (LED_BUILTIN, !digitalRead (LED_BUILTIN)) ;
const uint32_t errorCode = can1.beginFD (settings) ;
if (0 == errorCode) {
Serial.println ("can configuration ok") ;
else{
Serial.print ("Error can configuration: 0x") ;
Serial.println (errorCode, HEX) ;
void loop () {
//--- Receive frame
CANFDMessage message ;
if (can1.receiveFD0 (message)) {
if ((message.type==message.CAN_DATA) && !message.ext && (message.id == 0x15E)) {
Serial.println(message.data[7]);
