Fedora 33 Linux: We are not able to detect the installed agent
Fedora 33, Google Chrome Version 108.0.5359.98 (Official Build) (64-bit)
After downloading the tar file, extracting it, and starting ./Arduino_Create_Agent, the install process in Chrome eventually says "We are not able to detect the installed agent." I've reinstalled several times and always get this result. Looking at previous similar problems, it's always seemed to be a missing library, but that doesn't seem to be the case here.
stderr says:
[0] ~/ArduinoCreateAgent >./Arduino_Create_Agent
INFO[0000] Version:1.2.7
INFO[0000] Hostname: hpbox
INFO[0000] Garbage collection is on using Standard mode, meaning we just let Golang determine when to garbage collect.
INFO[0000] You specified a serial port regular expression filter: usb|acm|com
INFO[0000] Your serial ports:
INFO[0000] {/dev/ttyACM0 0x8054 0x2341 281867475154305146202020FF041E28 false}
[GIN-debug] [WARNING] Running in "debug" mode. Switch to "release" mode in production.
  • using env: export GIN_MODE=release
  • using code: gin.SetMode(gin.ReleaseMode)
[GIN-debug] GET / --> main.homeHandler (2 handlers)
[GIN-debug] GET /certificate.crt --> main.certHandler (2 handlers)
[GIN-debug] DELETE /certificate.crt --> main.deleteCertHandler (2 handlers)
[GIN-debug] POST /upload --> main.uploadHandler (2 handlers)
[GIN-debug] GET /socket.io/ --> main.(*WsServer).ServeHTTP-fm (2 handlers)
[GIN-debug] POST /socket.io/ --> main.(*WsServer).ServeHTTP-fm (2 handlers)
[GIN-debug] WS /socket.io/ --> main.(*WsServer).ServeHTTP-fm (2 handlers)
[GIN-debug] WSS /socket.io/ --> main.(*WsServer).ServeHTTP-fm (2 handlers)
[GIN-debug] GET /info --> main.infoHandler (2 handlers)
[GIN-debug] POST /killbrowser --> main.killBrowserHandler (2 handlers)
[GIN-debug] POST /pause --> main.pauseHandler (2 handlers)
[GIN-debug] POST /update --> main.updateHandler (2 handlers)
[GIN-debug] GET /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] POST /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] PUT /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] PATCH /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] HEAD /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] OPTIONS /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] DELETE /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] CONNECT /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] TRACE /v2/*path --> github.com/gin-gonic/gin.WrapH.func1 (2 handlers)
[GIN-debug] [WARNING] You trusted all proxies, this is NOT safe. We recommend you to set a value.
Please check gin package - github.com/gin-gonic/gin - Go Packages for details.
[GIN-debug] Listening and serving HTTP on 127.0.0.1:8991
ERRO[0000] Could not find HTTPS certificate. Using plain HTTP only.
/tmp/installbuilder_installer_782376.log:
Log started 12/15/2022 at 09:46:39
Preferred installation mode : gtk
Trying to init installer in mode gtk
Mode gtk successfully initialized
Executing killall Arduino_Create_Agent
Script exit code: 1
Script output:
Script stderr:
Arduino_Create_Agent: no process found
Error running killall Arduino_Create_Agent: Arduino_Create_Agent: no process found
Executing killall Arduino_Create_Bridge
Script exit code: 1
Script output:
Script stderr:
Arduino_Create_Bridge: no process found
Error running killall Arduino_Create_Bridge: Arduino_Create_Bridge: no process found
Preparing to Install
Creating directory /home/moller/ArduinoCreateAgent
Unpacking files
Directory already exists: /home/moller/.config/autostart
Unpacking files
Directory already exists: /home/moller/ArduinoCreateAgent
Unpacking files
Unpacking /home/moller/ArduinoCreateAgent/InstallerIcon.png
Unpacking /home/moller/ArduinoCreateAgent/config.ini
Unpacking /home/moller/ArduinoCreateAgent/certmanager.sh
Unpacking /home/moller/ArduinoCreateAgent/Arduino_Create_Agent_cli
Creating Shortcut for Uninstall Arduino_Create_Agent
Creating Shortcut for arduino-create-agent
Creating Desktop Shortcut for Arduino Create Agent
Killing running instances of the agent
Script exit code: 1
Script output:
Script stderr:
Launching Agent
Executing /home/moller/ArduinoCreateAgent/Arduino_Create_Agent &
Script exit code: 0
Script output:
The problem is that over and over again in the browser console I'm getting:
GET http://127.0.0.1:8991/info net::ERR_BLOCKED_BY_CLIENT
GET http://127.0.0.1:8992/info net::ERR_BLOCKED_BY_CLIENT
GET http://127.0.0.1:8993/info net::ERR_BLOCKED_BY_CLIENT
GET http://127.0.0.1:8994/info net::ERR_BLOCKED_BY_CLIENT
GET http://127.0.0.1:8995/info net::ERR_BLOCKED_BY_CLIENT
GET http://127.0.0.1:8996/info net::ERR_BLOCKED_BY_CLIENT
GET http://127.0.0.1:8997/info net::ERR_BLOCKED_BY_CLIENT
GET http://127.0.0.1:8998/info net::ERR_BLOCKED_BY_CLIENT
GET http://127.0.0.1:8999/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8991/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8992/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8993/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8994/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8995/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8996/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8997/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8998/info net::ERR_BLOCKED_BY_CLIENT
GET https://localhost:8999/info net::ERR_BLOCKED_BY_CLIENT
If anyone has a fix for this, it would be great. So far, tinkering with the firewall hasn't helped.
