Feeding analog signal into digital pins
I'm working on a project where I'm using force sensors (https://www.sparkfun.com/products/9375) to detect touch. Since I only need to know whether the sensor is being touched and not the force of the touch I was wondering whether there's any way I can feed the signal into a digital pin. I am very limited on analog pins on account of other sensors I'm using.
(I chose the force sensor for its form factor because it's going into the finger pads of gloves. Suggestions on an alternate sensor that would give a digital input on touch are welcomed as well.)
Try to connect to a digital pin and ground, with the internal pull-up resistor enabled (INPUT_PULLUP).
"LOW" == force.
If it's too sensitive, try/add an external 10k pull-up resistor. Leo..
