FEETECH 7.4 35KG Servo (360 version / FT6335M )
i am having issue getting this servo to continuously rotating
its currently running with 0 load from the 5v port off the arduino, i also have a PSU for my breadboard which is also 5V
no matter what code i try i can not get the servo continuously rotating
dose anyone have any experience with the FT6335M
Regards
Matt
For heavens sake abort that doing before You burn the Arduino, if it's not already crippled.
Never power such things from any Arduino board!
Yes, 5 volt... Have You ever heard about current, amperes? Those tiny copper strips on the board are dimensioned for milliamp currents.
It’s now being powered by a 7.4 supply but still no luck
What kind of supply (current capability).
Did you share grounds.
Code and a picture could help.
Leo..
I’ve got an adjustable psu
The common ground has been shared from the arduino to the breadboard
I’ll upload the code and a diag when I get home
More than luck is needed. Please post schematics. Pen and paper is often good enough.
#include <Arduino.h>
#include <U8g2lib.h>
#include <SPI.h>
#include <Wire.h>
#include <Servo.h>
#include <EEPROM.h>
int addr = 0;
Servo myservo;
// ********** encoder pins ***************
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0);
#define pin_CLK 3 // CLK A
#define pin_DT  4 // DT B
#define pin_Btn 2 // switch
int count1;
unsigned long CurrentTime, PrevEncoderTime;
enum eEncoderState {eNone, eLeft, eRight, eButton};
eEncoderState EncoderState;
int EncoderA, EncoderB, EncoderAPrev, counter;
bool ButtonPrev;
// ********** Function  ***************
eEncoderState GetEncoderState();
float A, B, C, Atemp,value;
int buttonpress=0;
  myservo.attach(9);
  u8g2.begin();
  pinMode(pin_CLK, INPUT);
  pinMode(pin_DT,  INPUT);
  pinMode(pin_Btn, INPUT_PULLUP);
  count1 = EEPROM.read(addr);
  count1 = (count1, DEC);
     u8g2.clearBuffer();          // clear the internal memory
     u8g2.setFont(u8g2_font_logisoso28_tr);  // choose a suitable font
     u8g2.drawStr(3,30,"Welcome"); // write something to the internal memory
     u8g2.sendBuffer();         // transfer internal memory to the display
     delay(300);
myservo.writeMicroseconds(1500);
while (1)
    EncoderState = GetEncoderState();
    switch (EncoderState) {
      case eNone: {
          continue;
      case eButton: {
                  EEPROM.write(addr, count1);
                  //if(buttonpress == 0)
                      buttonpress = 1;
                  else if(buttonpress == 1)
                    buttonpress = 0;
                  String string2;
                  string2 = String(count1);
                  String col2 ="count:";
                  col2.concat(string2);
                  char charBuf2[50];
                  col2.toCharArray(charBuf2, 50);
                    //u8g2.setFont(u8x8_font_chroma48medium8_r);
                    u8g2.drawStr(3,30,charBuf2); // write something to the internal memory
                    delay(300);
      case eLeft: {
          count1++;
                  String stringa;
                  stringa = String(count1);
                  String col ="Set: ";
                  col.concat(stringa);
                  char charBuf[50];
                  col.toCharArray(charBuf, 50);
                    u8g2.drawStr(3,30,charBuf); // write something to the internal memory
      case eRight: {
         // if (DefaultValue < MaxValue) DefaultValue++;
         if(count1 > 0)
          count1--;
           String stringb;
                  stringb = String(count1);
                  String col1 ="Set:";
                  col1.concat(stringb);
                  char charBuf1[50];
                  col1.toCharArray(charBuf1, 50);
                    u8g2.drawStr(3,30,charBuf1); // write something to the internal memory
  // control servo
     u8g2.drawStr(3,30," Start"); // write something to the internal memory
     delay(300);
  for(int i =0 ; i<=count1 ; i++)
    myservo.writeMicroseconds(2000);
    delay(2000);
    //myservo.writeMicroseconds(1500);
    //delay(1000);
    buttonpress = 0 ;
     u8g2.drawStr(3,30," Done"); // write something to the internal memory
     delay(200);
// ******************** Encoder with button********************
eEncoderState GetEncoderState() {
  // Reading the state of the encoder
  eEncoderState Result = eNone;
  CurrentTime = millis();
  if (CurrentTime >= (PrevEncoderTime + 5)) {
    PrevEncoderTime = CurrentTime;
    if (digitalRead(pin_Btn) == LOW ) {
      if (ButtonPrev) {
        Result = eButton; // Button pressed
        ButtonPrev = 0;
    else {
      ButtonPrev = 1;
      EncoderA = digitalRead(pin_DT);
      EncoderB = digitalRead(pin_CLK);
      if ((!EncoderA) && (EncoderAPrev)) { // Signal A changed from 1 to 0
        if (EncoderB) Result = eRight;     // B=1 => encoder rotates clockwise
        else          Result = eLeft;      // B=0 => encoder rotates counterclockwise
      EncoderAPrev = EncoderA; // remember the current state
  return Result;
basically i want to turn the encoder to select a number
you hit enter and the servo turns untill X number has been reached
im trying to load BBs into airsoft magazines
