Fehler beim Hochladen auf das Board
Hallo,
ich benutze das Arduino seit einem Monat, lief alles super. Jetzt kann ich keine Sketche mehr hoch laden, die Fehlermeldung verstehe ich nicht:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Dokumente\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659 -warnings=none -build-cache C:\Users\JudithR\AppData\Local\Temp\arduino_cache_47639 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\Dokumente\Arduino\sketch_mar08a\sketch_mar08a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Dokumente\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659 -warnings=none -build-cache C:\Users\JudithR\AppData\Local\Temp\arduino_cache_47639 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose D:\Dokumente\Arduino\sketch_mar08a\sketch_mar08a.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659\sketch\sketch_mar08a.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659\sketch\sketch_mar08a.ino.cpp" -o "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659\preproc\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659\sketch\sketch_mar08a.ino.cpp" -o "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659\sketch\sketch_mar08a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659/sketch_mar08a.ino.elf" "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659\sketch\sketch_mar08a.ino.cpp.o" "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659/..\arduino_cache_47639\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\JudithR\AppData\Local\Temp\arduino_build_660659" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659/sketch_mar08a.ino.elf" "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659/sketch_mar08a.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659/sketch_mar08a.ino.elf" "C:\Users\JudithR\AppData\Local\Temp\arduino_build_660659/sketch_mar08a.ino.hex"
Der Sketch verwendet 928 Bytes (2%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 9 Bytes (0%) des dynamischen Speichers, 2039 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
Beim Hochladen des Sketches ist ein Fehler aufgetreten
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x50
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
Ich habe die Software neu installiert, hilft aber nichts.
Bin euch für eine verständöiche Anfänger-Hilfe sehr sehr dankbar!
Überprüfe, welche serielle Schnittstelle COMx im Werkzeug-Menue eingestellt ist. Die muss zum USB-Treiber für das gewählte Board passen.
Manchmal wirdt nur die Liste der COMx dargestellt, manchmal erscheint noch Text daneben, der besagt, für welches Arduino-Board die Schnittstelle gedacht ist.
Mir hat es auch schon geholfen, dass ich einfach kurz den USB-Stecker gezogen und wieder angesteckt habe.
Viel Erfolg
SupArdu
Hi
Manch Mal hilft es, die Meldungen einfach zu lesen.
Das lässt darauf schließen, daß Da der Programmer nicht antwortet - warum/wieso ist nun wieder Dein Part.
Hast Du im Geräte-Manager ein 'unbekanntes Gerät'? (Win)
Dann kann es sein, daß der Treiber für den Programmer einfach nur nicht mehr funktioniert.
Die Fehlermeldungen sind übrigens keine Fehler, da dann der Sketch nicht kompilieren würde.
Habe den Buchstabenhaufen jetzt aber nicht wirklich durchgeackert, ist grauenhaft zu lesen, auch hier hätten Code-Tags geholfen.
MfG
Hallo,
erstmal danke für eure Tipps - leider hat bis jetzt nichts geholfen. Ich habe die komplette Troubleshooting Liste von der Arduino-Website durch getestet. Software neu installiert, USB Kabel gewechselt, Neustart, Port-Treiber Update. Der Gerätemanager erkennt das Arduino mit COM3, der Port ist auch im Werkzeugmenue ausgewählt.
Ich habe nur das USB Kabel angeschlossen und versuche, Codes aus den Basic Beispielen zu laden. Keiner funktioniert.
Hier sind nochmal nur die roten Teile der Fehlermeldung kopiert. Habe sie gegoogelt, was mich aber nur wieder zur möglichen Annahme gebracht hat, dass doch was an der Hardware kaputt gegangen ist. Das Board ist ein "Funduino Uno" also kein Original.
Also nochmal vielen Dank für Ideen!
Archiving built core (caching) in: C:\Users\JudithR\AppData\Local\Temp\arduino_cache_276086\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x39
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x39[code]
Hast Du etwas an die Pins D0 und D1 angeschlossen??
Grüße Uwe
Wie sieht es mit deinem Bootloader auf dein Board aus?
ich hatte mal das selbe Problem. Habe dann in der IDE unter "Werkzeuge" den Bootloader gebrannt und es ging wieder.
Viel Glück
Hallo Uwe,
nein nur das USB Kabel zum Laptop.
Beim Versuch den Bootloader über Werkzeuge zu brennen kommt auch eine Fehlermeldung:
Fehler beim Brennen des Bootloaders.
Danke trotzdem!
Zum Bootloader brennen brauchst du einen ISP Programmer.
Alternativ, einen weiteren Arduino.
Wenn dann noch das Bootloader brennen versagt, ist dein Arduino kaputt (oder du hast die beiden falsch zusammen geklemmt)
combie:
mit ISP Sketch
