Hallo zusammen.
Ich hab folgendes Problem:
Die IDE war 'eingefroren'. Nach dem Neustart des Rechners kommt folgende Fehlermeldung:
Der Sketch:
Serial.begin(19200);
Die Meldung:
Arduino: 1.8.9 (Windows 10), Board: "ATtiny25/45/85, ATtiny85, Internal 16 MHz"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kjzil\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kjzil\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Arduino\libraries -fqbn=attiny:avr:ATtinyX5:cpu=attiny85,clock=internal16 -vid-pid=1A86_7523 -ide-version=10809 -build-path C:\Users\kjzil\AppData\Local\Temp\arduino_build_797112 -warnings=default -build-cache C:\Users\kjzil\AppData\Local\Temp\arduino_cache_993989 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.arduinoOTA.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose D:\Arduino\sketch_may10a\sketch_may10a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kjzil\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kjzil\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Arduino\libraries -fqbn=attiny:avr:ATtinyX5:cpu=attiny85,clock=internal16 -vid-pid=1A86_7523 -ide-version=10809 -build-path C:\Users\kjzil\AppData\Local\Temp\arduino_build_797112 -warnings=default -build-cache C:\Users\kjzil\AppData\Local\Temp\arduino_cache_993989 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.arduinoOTA.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose D:\Arduino\sketch_may10a\sketch_may10a.ino
Using board 'ATtinyX5' from platform in folder: C:\Users\kjzil\AppData\Local\Arduino15\packages\attiny\hardware\avr\1.0.2
Using core 'arduino' from platform in folder: C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23
Detecting libraries used...
"C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_attiny -DARDUINO_ARCH_AVR "-IC:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\kjzil\AppData\Local\Arduino15\packages\attiny\hardware\avr\1.0.2\variants\tiny8" "C:\Users\kjzil\AppData\Local\Temp\arduino_build_797112\sketch\sketch_may10a.ino.cpp" -o nul
Generating function prototypes...
"C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_attiny -DARDUINO_ARCH_AVR "-IC:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\kjzil\AppData\Local\Arduino15\packages\attiny\hardware\avr\1.0.2\variants\tiny8" "C:\Users\kjzil\AppData\Local\Temp\arduino_build_797112\sketch\sketch_may10a.ino.cpp" -o "C:\Users\kjzil\AppData\Local\Temp\arduino_build_797112\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\kjzil\AppData\Local\Temp\arduino_build_797112\preproc\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=attiny85 -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_attiny -DARDUINO_ARCH_AVR "-IC:\Users\kjzil\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\kjzil\AppData\Local\Arduino15\packages\attiny\hardware\avr\1.0.2\variants\tiny8" "C:\Users\kjzil\AppData\Local\Temp\arduino_build_797112\sketch\sketch_may10a.ino.cpp" -o "C:\Users\kjzil\AppData\Local\Temp\arduino_build_797112\sketch\sketch_may10a.ino.cpp.o"
D:\Arduino\sketch_may10a\sketch_may10a.ino: In function 'void setup()':
sketch_may10a:3:3: error: 'Serial' was not declared in this scope
exit status 1
Kann mir da jemand helfen?
Eine Neuinstallation der IDE hat nicht geholfen.
Danke und Gruß
Kally
