Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Jochen\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Jochen\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jochen\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\Jochen\AppData\Local\Temp\arduino_build_389497 -warnings=default -build-cache C:\Users\Jochen\AppData\Local\Temp\arduino_cache_68996 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\Jochen\Documents\Arduino\DCF_RTC_LCD\DCF_RTC_LCD.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Jochen\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Jochen\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Jochen\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\Jochen\AppData\Local\Temp\arduino_build_389497 -warnings=default -build-cache C:\Users\Jochen\AppData\Local\Temp\arduino_cache_68996 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\Jochen\Documents\Arduino\DCF_RTC_LCD\DCF_RTC_LCD.ino
Using board 'uno' from platform in folder: C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Using core 'arduino' from platform in folder: C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5
Detecting libraries used...
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o nul
Alternatives for DS3231.h: [DS3231@1.1.0]
ResolveLibrary(DS3231.h)
-> candidates: [DS3231@1.1.0]
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o nul
Alternatives for RTClib.h: [RTClib@2.1.1]
ResolveLibrary(RTClib.h)
-> candidates: [RTClib@2.1.1]
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.14.1]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.14.1]
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o nul
Alternatives for DCF77.h: [DCF77@1.0.0]
ResolveLibrary(DCF77.h)
-> candidates: [DCF77@1.0.0]
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o nul
Alternatives for TimeLib.h: [Time-master@1.6.1]
ResolveLibrary(TimeLib.h)
-> candidates: [Time-master@1.6.1]
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o nul
Alternatives for LiquidCrystal_I2C.h: [Arduino-LiquidCrystal-I2C-library-master NewLiquidCrystal_lib LiquidCrystal_I2C@1.1.2]
ResolveLibrary(LiquidCrystal_I2C.h)
-> candidates: [Arduino-LiquidCrystal-I2C-library-master NewLiquidCrystal_lib LiquidCrystal_I2C@1.1.2]
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231\\DS3231.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src\\utility\\twi.c" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src\\RTC_DS1307.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src\\RTC_DS3231.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src\\RTC_Micros.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src\\RTC_Millis.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src\\RTC_PCF8523.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src\\RTC_PCF8563.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src\\RTClib.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77\\utility" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77\\DCF77.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77\\utility" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77\\utility\\Utils.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master\\DateStrings.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master\\Time.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C\\LiquidCrystal_I2C.cpp" -o nul
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src\\SPI.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\cores\\arduino" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\variants\\standard" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DS3231" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\Wire\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\RTClib\\src" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\DCF77" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\Time-master" "-IC:\\Users\\Jochen\\Documents\\Arduino\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\Jochen\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries\\SPI\\src" "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp" -o "C:\\Users\\Jochen\\AppData\\Local\\Temp\\arduino_build_389497\\sketch\\DCF_RTC_LCD.ino.cpp.o"
In file included from C:\Users\Jochen\Documents\Arduino\DCF_RTC_LCD\DCF_RTC_LCD.ino:5:0:
C:\Users\Jochen\Documents\Arduino\libraries\RTClib\src/RTClib.h:143:7: error: redefinition of 'class DateTime'
class DateTime {
In file included from C:\Users\Jochen\Documents\Arduino\DCF_RTC_LCD\DCF_RTC_LCD.ino:1:0:
C:\Users\Jochen\Documents\Arduino\libraries\DS3231/DS3231.h:27:7: note: previous definition of 'class DateTime'
class DateTime {
Mehrere Bibliotheken wurden für "LiquidCrystal_I2C.h" gefunden
Benutzt: C:\Users\Jochen\Documents\Arduino\libraries\LiquidCrystal_I2C
Nicht benutzt: C:\Users\Jochen\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master
Nicht benutzt: C:\Users\Jochen\Documents\Arduino\libraries\NewLiquidCrystal_lib
Bibliothek DS3231 in Version 1.1.0 im Ordner: C:\Users\Jochen\Documents\Arduino\libraries\DS3231 wird verwendet
Bibliothek Wire in Version 1.0 im Ordner: C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire wird verwendet
Bibliothek RTClib in Version 2.1.1 im Ordner: C:\Users\Jochen\Documents\Arduino\libraries\RTClib wird verwendet
Bibliothek Adafruit_BusIO in Version 1.14.1 im Ordner: C:\Users\Jochen\Documents\Arduino\libraries\Adafruit_BusIO wird verwendet
Bibliothek DCF77 in Version 1.0.0 im Ordner: C:\Users\Jochen\Documents\Arduino\libraries\DCF77 wird verwendet
Bibliothek Time-master in Version 1.6.1 im Ordner: C:\Users\Jochen\Documents\Arduino\libraries\Time-master wird verwendet
Bibliothek LiquidCrystal_I2C in Version 1.1.2 im Ordner: C:\Users\Jochen\Documents\Arduino\libraries\LiquidCrystal_I2C wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: C:\Users\Jochen\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI wird verwendet
exit status 1
Fehler beim Kompilieren für das Board Arduino Uno.
#include <RTClib.h>
#include <DS3231.h>
#include "DCF77.h" //Alle DCF77 Funktionen laufen ueber diese Bibliothek.
#include "TimeLib.h" //Time.h hat bei mir nie funktioniert, habe TimeLib.h eingebunden, dann gehts.
#include <Wire.h>
int Motor = 3;
int Schieb1 = 4;
int Stp = 5;
int Schieb2 = 6;
int Std;
int DCF77PIN2 ;
int Min;
int Zahl;
void Abfrage(int);
void Minuten(int);
void Stunden(int);
#define DCF_PIN 2 // Verbindung zum DCF77 Arduino UNO PIN
#define DCF_INTERRUPT 0 // Interrupt number associated with pin
#define PIN_LED 13 // Status von der Verbindung an LED-PIN 13
//DCF77 DCF = DCF77(DCF_PIN, DCF_INTERRUPT); // Dieser Eintrag sollte für andere Module aktiviert werden...
// für das DCF-Modul von ELV muss das Signal invertiert werden, deshalb so:
DCF77 DCF = DCF77(DCF_PIN, DCF_INTERRUPT, false); // false für invertiertes Signal
bool g_bDCFTimeFound = false; // wurde ein gueltiges DCF77 Signal gefunden?
// Librarys für LCD-Display
LiquidCrystal_I2C lcd(0x26, 20, 4); //Hier wird festgelegt um was für einen Display es sich handelt.
// Library für RTC DS3231
// Das Uhrenmodul wird angeschlossen A4 - SDA, A5 - SCL
// (Jahr, Monat, Tag, Stunde, Minute, Sekunde)
// rtc.adjust(DateTime(2019, 1, 21, 3, 0, 0));
#include "RTClib.h"
RTC_DS3231 rtc; // Es wird eine Objekt rtc aus der Klasse RTC_3231 der RTClib.h erstellt
// Variablen für die Auswertung und den Abgleich der Zeiten
byte ErstStart = 1;
byte DCFaktiv = 0;
byte DCFZeitOK = 0;
long Intervall = 120000; // Abfrageintervall 2 Minuten
long UpdateTimer = 0; // Zwischenspeicher für die Wartezeit
pinMode(Motor, OUTPUT);
pinMode(Schieb1, OUTPUT);
pinMode(Stp, OUTPUT);
pinMode(Schieb2, OUTPUT);
pinMode(DCF77PIN2, INPUT);
pinMode(PIN_LED, OUTPUT);
Serial.begin(9600); // Seriellen Monitor starten
DCF.Start(); // DCF Uhr starten
DCFaktiv = 1; // Merker, dass das DCF77 Signal ausgerwetet wird, man kann das mit DCF.Stop(); anhalten
rtc.begin(); // RTC DS3231 starten
lcd.init(); //Im Setup wird der LCD gestartet
lcd.backlight(); //Hintergrundbeleuchtung einschalten (lcd.noBacklight(); schaltet die Beleuchtung aus).
lcd.setCursor(0, 3); // Spalte, Zeile, 0, 0 entspricht 1. Spalte oder 1. Zeile
lcd.print("DCF77 RTC LCD V1.0");
lcd.setCursor(0, 2); // Spalte, Zeile, 0, 0 entspricht 1. Spalte oder 1. Zeile
lcd.print("DCF77 aktiv: "); lcd.print(DCFaktiv);
Serial.println("Warte auf DCF77 Zeit... ");
Serial.println("Es dauert meistens ca. 2 Minuten bis die Zeit aktualisiert ist");
// das Signal wird nur alle 5 Sekunden abgefragt
delay(5000);
digitalWrite(PIN_LED, HIGH);
delay(50);
digitalWrite(PIN_LED, LOW);
DCFZeitOK = 0; // noch kein gültiges DCF-Telegramm empfangen
time_t DCFtime = DCF.getTime(); // Prüfen ob eine neue DCF77 Zeit verfügbar ist
if (DCFtime != 0)
Serial.println("Aktuelle Zeit wurde empfangen!");
setTime(DCFtime);
g_bDCFTimeFound = true;
DCFZeitOK = 1;
// die Uhrzeit wurde gesetzt, also LED nach kurzer Zeit ein
if (g_bDCFTimeFound)
delay(50);
if ((DCFZeitOK = 1) && (year() > 2019) && (((millis() - UpdateTimer) > Intervall)) )
ErstStart = 0;
// Wenn eine gültige DCF77 Zeit vorliegt, das DCF Jahr > 2019 und Intervall vergangen ist, die RTC aktualisieren
RTCUpdate();
UpdateTimer = millis();
lcd.print("Sync: ");
DateTime now = rtc.now();
//Stunde = (now.hour()); Minute = (now.minute()); Sekunde = (now.second());
if (now.hour() < 10) {
lcd.print("0");
} lcd.print(now.hour()); lcd.print(":");
if (now.minute() < 10) {
lcd.print("0");
} lcd.print(now.minute()); lcd.print(":");
if (now.second() < 10) {
lcd.print("0");
} lcd.print(now.second()); lcd.print(" ");
digitalClockDisplay(); // DCF77 Zeit anzeigen
Stunden();
RTCClockDisplay(); // RTC- Zeit anzeigen
void RTCUpdate()
Serial.println("Stelle RCT neu! ");
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
// Datum und Uhrzeit der FCF77 in RTC übertragen
rtc.adjust(DateTime(year(), month(), day(), hour(), minute(), second()));
void RTCClockDisplay()
// Anzeigen der RTC-Zeit auf dem 20x4 LCD-Display
int Stunde; int Minute; int Sekunde;
int Tag; int Monat; int Jahr;
Jahr = (now.year()); Monat = (now.month()); Tag = (now.day());
lcd.setCursor(0, 1);
if (Stunde < 10) {
lcd.print("0");
} lcd.print(Stunde); lcd.print(":");
if (Minute < 10) {
lcd.print("0");
} lcd.print(Minute); lcd.print(":");
if (Sekunde < 10) {
lcd.print("0");
} lcd.print(Sekunde); lcd.print(" ");
if (Tag < 10) {
lcd.print("0");
} lcd.print(Tag); lcd.print(".");
if (Monat < 10) {
lcd.print("0");
} lcd.print(Monat); lcd.print(".");
lcd.print(Jahr);
void digitalClockDisplay()
// Anzeigen der Zeit auf dem 20x4 LCD-Display
lcd.setCursor(0, 0);
if (hour() < 10) {
lcd.print("0");
} lcd.print(hour()); lcd.print(":");
if (minute() < 10) {
lcd.print("0");
} lcd.print(minute()); lcd.print(":");
if (second() < 10) {
lcd.print("0");
} lcd.print(second()); lcd.print(" ");
//lcd.setCursor(0, 1);
if (day() < 10) {
lcd.print("0");
} lcd.print(day()); lcd.print(".");
if (month() < 10) {
lcd.print("0");
} lcd.print(month()); lcd.print(".");
lcd.print(year());
// Anzeigen der Zeit auf dem seriellen Monitor am PC
Serial.print(" ");
Serial.print(" ");
Serial.print(" ");
void printDigits(int digits)
// Kleines Skript um bei Minuten und Sekunden eine 0 vorne an zu stellen
Serial.print(":");
if (digits < 10)
Serial.print('0');
Serial.print(digits);
void Abfrage(void)
Motor = HIGH;
delay(10000);
Motor = LOW;
Schieb1 = HIGH;
Schieb2 = LOW;
Stp = HIGH;
Stp = LOW;
Schieb2 = HIGH;
Schieb2 = LOW;
return;
void Minuten (int) {
// digitalRead(DCF77PIN2);
// serialDumpTime();
if (Min == 00)
Abfrage();
else if (Min == 20)
Abfrage();
else (Min == 40);
Abfrage();
return;
void Stunden (void) {
if (Std <= 7)
return;
else if (Std == 7)
Minuten(Zahl);
else if (Std <= 21)
Minuten(Zahl);
else if (Std <= 24)
return;
