Fehlermeldung beim hochladen auf den Nano
Hallo,
ich habe folgenden Code. Leider bekomme ich immer eine Fehlermeldung und habe keine Ahnung, wie ich das lösen kann.
/* Portal Turret - Option With Radio!!
 *  Chris Nowak - Feb 2019
 *  https://www.instructables.com/member/ChrisN219/
 *  https://create.arduino.cc/projecthub/Novachris/talking-portal-2-turret-gun-637bf3
 *  This code includes all the features needed to perform the Cara Mia Opera,
 *  Chat Time and Manual mode, as controlled by the Maseter Turret Control (MTC).
 *  The MTC is a separate controller featured on another build.  The turret
 *  will operate autonomously using this code without the MTC.
 *  The code is built to work with three turrets, but each will operate independently.
 *  Lots of debugging code left in.  Use or clean up as desired.  It's mostly debugged,
 *  but isn't perfect.  Given the price you paid, I figure that's ok! ;)
 * ================= RED ====================
#include <Wire.h>
#include <VL53L0X.h>
#include "Arduino.h"
#include <SoftwareSerial.h>
#include <Servo.h>
#include <DFMiniMp3.h>
#include <RF24.h>
#include <RF24Network.h>
#include <SPI.h>
class Mp3Notify
public:
  static void OnError(uint8_t errorCode)
//    see DfMp3_Error for code meaning
    Serial.print("Com Error ");
    Serial.println(errorCode);
  static void OnPlayFinished(uint8_t globalTrack)
    Serial.print("Play finished for #");
    Serial.println(globalTrack);
  static void OnCardOnline(uint8_t code)
    Serial.print("Card online ");
    Serial.println(code);
  static void OnCardInserted(uint8_t code)
    Serial.print("Card inserted ");
  static void OnCardRemoved(uint8_t code)
    Serial.print("Card removed ");
Servo servo_pivot;
Servo servo_wings;
Servo servo_pitch;
VL53L0X sensor;
//Setup for soundcard
SoftwareSerial secondarySerial(4, 2); // RX, TX
DFMiniMp3<SoftwareSerial, Mp3Notify> mp3(secondarySerial);
//Setup for radio
RF24 radio(10, 9);               // nRF24L01 (CE,CSN)
RF24Network network(radio);      // Include the radio in the network
const uint64_t this_node = 01;   // This turret  - Red - in Octal format ( 04,031, etc)
const uint64_t WHT = 02;      // Turret 02 - White
const uint64_t BLU = 03;      // Turret 03 - Blue
const uint64_t MTC = 00;      // Master Turret Control
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
unsigned long previousMillis3 = 0;
byte LED_LH_up = A1;
byte LED_LH_down = A2;
byte LED_CENTRE = A3;
byte LED_RH_up = 7;
byte LED_RH_down = 8;
byte PIVOT = 6; //white
byte WINGS = 3; //yellow
byte PITCH = 5; //blue
byte parkPIVOT = 96;  //Smaller number rotates CW as viewed from the top
byte posPIVOT = 96;
byte maxPIVOT = 116;
byte minPIVOT = 76;
byte WINGclose = 165;
byte WINGopen = 10;
byte WINGpos = 160;
byte parkPITCH = 86;
byte posPITCH = 86;
byte maxPITCH = 96;
byte minPITCH = 75;
byte pos = 90;
byte pulse = 20;
byte pitchCW = 1;
byte pivotCW = 1;
byte randomWake;
byte randomOpen;
byte randomFalse;
byte randomStart;
byte randomDisengage;
int triggerDistance = 300;
byte buttonStatus;
byte busyRed = 1;
byte restModeWhite;
byte goState;
int x;
int y;
byte pb1State; // Fire
byte pb2State; // say random comment
byte pb3State;
byte randomPic;
//Payload from Master Turret Control (MTC)
int payload [] = {0, 1,    2    ,    3    ,     4   ,    5   };
//int payload [] = {x, y, pb1State, pb2State, pb3State, goState};
//int payload [6];
/* This is the "conversation" map for "Chat Time".
 * 0-99 = Red Turret sayings
 * 100-199 = White Turret sayings
 * 200-299 = Blue Turret sayings
 * Files on all SD cards are saved as 0-100.
 * Add 100 to the file number here for White, 200 for Blue.
 * File 204 would be BLUE turret, file number 0004.
int chatSayings [] = {
  0,              // Start pause on i = 0, followed by "rounds"...
  204, 164, 25,   // 1
  205, 127, 76,   // 2
  208, 162, 65,   // 3
  143, 230, 23,   // 4
  130, 41, 225,   // 5
  153, 31, 133,   // 6
  234, 49, 155,   // 7
  229, 175, 74,   // 8
  231, 58, 226,   // 9
  161, 223, 59,   // 10
  227, 68, 236,   // 11
  136, 50, 224,   // 12
  34, 160, 78,    // 13
  222, 42         // End
/* This is the RED and WHITE turret timing map.  They share sayings.
 *  These timings correspond to the time needed
 *  to play the individual sayings, in milliseconds.
 *  Change the sayings above as desired, but do not change these timings.
 *  For example, i = 2 will take 0.8 seconds (NormalTimings[2])
 *  to play the chatSayings[2] file.
int NormalTimings [] = {
1000,  // Start pause on i = 0, followed by "rounds"...
2600, 800, 2800, 900, 1700, 1600, 1300, 2500, 1400, 1900,     // 1 - 10
1600, 2300, 800, 3000, 300, 100, 200, 0, 0, 300,              // 11 - 20
298000, 1300, 2600, 1300, 1400, 2100, 1900, 1600, 800, 1700,  // 21 - 30
1100, 1000, 1000, 2100, 1500, 1300, 1100, 800, 1200, 1000,    // 31 - 40
2200, 1700, 1300, 1400, 1500, 1000, 2000, 500, 2700, 9000,    // 41 - 50
1100, 1200, 900, 2400, 1200, 1100, 2100, 2000, 2500, 1700,    // 51 - 60
1100, 1000, 1100, 500, 1900, 0, 1300, 2100, 1700, 900,        // 61 - 70
1100, 800, 1100, 1700, 1100, 1100, 1500, 1500, 500, 900,      // 71 - 80
2100                                                          // 81
/* This is the BLUE turret timing map.
 *  to play the individual sayings, in seconds.
 *  For example, i = 2 will take 0.9 seconds (DefectiveTimings[2])
 *  to play the chatSayings [2] file.
int DefectiveTimings [] = {
1700, 900, 2000, 600, 1100, 1800, 1900, 3000, 1500, 800,    // 1 - 10
2100, 800, 1900, 900, 3200, 2700, 0, 0, 0, 2000,            // 11 - 20
4400, 800, 3200, 900, 1400, 2000, 2100, 1200, 1300, 1000,   // 21 - 30
1100, 1400, 2100, 1000, 1600, 1000, 1200                    // 31 - 40
//======================= SETUP =================================//
void setup(){
   secondarySerial.begin(9600);//
   mp3.begin();
   mp3.setVolume(22);
   Wire.begin();
   SPI.begin();  // Radio setup
   radio.begin();
   radio.setPALevel(RF24_PA_LOW); // set radio to low power.  All near each other
   radio.setDataRate(RF24_2MBPS); // I find this works best with multiple radios
   network.begin(70, this_node);  //(channel, node address)
   sensor_read();
   pinMode(LED_LH_up, OUTPUT);
   pinMode(LED_LH_down, OUTPUT);
   pinMode(LED_CENTRE, OUTPUT);
   pinMode(LED_RH_up, OUTPUT);
   pinMode(LED_RH_down, OUTPUT);
   digitalWrite(LED_CENTRE, HIGH);
   activate_servos();
   servo_wings.write(WINGopen); // open wings
   servo_pivot.write(parkPIVOT); // park pivot
   servo_pitch.write(parkPITCH); // park pitch
   randomWake = random(1, 3);
   mp3.playMp3FolderTrack(1); // play waking up comment
   delay(2000);
   servo_wings.write(WINGclose); // close wings
   delay(1500);
   digitalWrite(LED_CENTRE, LOW);
   turn_off_servos();
   busyRed = 0;
//======================= MAIN LOOP =============================//
void loop(){
  while (sensor.readRangeSingleMillimeters()>triggerDistance) { //nothing in front of sensor, do nothing
    ReadNet();
    WriteNet();
    output_sensor();
    if (payload[5] == 1) { // Conditions used with MTC. Turret will work automatically without MTC
      WriteNet();
      Cara_Mia(); // Opera time!!
    else if (payload[5] == 2) {
      WriteNet();
      Chatty_time(); // Chatty time!!}
      ReadNet();
    else if (payload[5] == 3) {
      WriteNet();
      ManualControl (); // Manual Control
  if (sensor.readRangeSingleMillimeters()<triggerDistance){ //something in front of sensor
    delay (200); //wait before checking again to see if someone still there...
    if (sensor.readRangeSingleMillimeters()<triggerDistance){ //someone there (not false trigger)
      busyRed = 1;
      ReadNet();
      WriteNet();
      output_sensor();
      activate_servos(); // wake up servos
      activate(); // open wings and say "I see you" comment
      if (sensor.readRangeSingleMillimeters()>triggerDistance){ // opened up and person gone
        falseActivate();  //say "where'd you go?" comment and close up
        delay (2000);
        scanArea(); //perform scan of area
      else { // someone definitely there - open fire!!
        engage();
        delay (2400);
        for (int j=0; j <= 2; j++){
          if (sensor.readRangeSingleMillimeters()<triggerDistance){ // as long as someone there...
            for (int i=0; i <= 25; i++){ // fire for a short period
              fire();} // shoot them...
            output_sensor();
    output_sensor();
    disengage(); // no more target, stop firing and prepare to close
  else {
    output_sensor();
    delay(350);
//======================= SUBROUTINES ===========================//
//=====  read the VLX53 sensor  =====//
void sensor_read(){
  sensor.init();
  sensor.setTimeout(100);
  // lower the return signal rate limit (default is 0.25 MCPS)
  sensor.setSignalRateLimit(0.25); // started with 0.1
  // increase laser pulse periods (defaults are 14 and 10 PCLKs)
  sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodPreRange, 14); //started with 18
  sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodFinalRange, 10); //started with 14
//=====  monitor output for debugging  =====//
void output_sensor(){ // Option out or delete if not interested.
  Serial.print ("-RED-  ");
  Serial.print("Distance "); Serial.print(sensor.readRangeSingleMillimeters()); Serial.print ("\t");
  if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
  Serial.print(F("Pivot< ")); Serial.print (posPIVOT); Serial.print ("   ");
  Serial.print(F("Pitch< ")); Serial.print (posPITCH); Serial.print ("   ");
  Serial.print(F("Wings< ")); Serial.print (WINGpos); Serial.print ("   ");
  Serial.print(F("busyRed: "));Serial.print (busyRed); Serial.print ("   ");
  Serial.print(F("x :"));Serial.print (payload[0]); Serial.print ("\t");
  Serial.print(F("y :"));Serial.print (payload[1]); Serial.print ("\t");
  Serial.print(F("pb1 :"));Serial.print (payload[2]); Serial.print ("   ");
  Serial.print(F("pb2 :"));Serial.print (payload[3]); Serial.print ("   ");
  Serial.print(F("pb3 :"));Serial.print (payload[4]); Serial.print ("   ");
  Serial.print(F("goState: ")); Serial.print(payload[5]);Serial.print ("   ");
//=====  update servo positions =====//
void increment_servos(){
  if (pitchCW == 0) posPITCH = posPITCH - 3; // the higher the number, the jerkier the motion
  if (pitchCW == 1) posPITCH = posPITCH + 3;
  if (pivotCW == 0) posPIVOT = posPIVOT - 3;
  if (pivotCW == 1) posPIVOT = posPIVOT + 3;
  if (posPIVOT >= maxPIVOT) pivotCW = 0;
  if (posPIVOT <= minPIVOT) pivotCW = 1;
  if (posPITCH >= maxPITCH) pitchCW = 0;
  if (posPITCH <= minPITCH) pitchCW = 1;
//======================= ACTIVATE ==============================//
void activate(){ // open up wings and say something
  busyRed = 1;
  ReadNet();
  WriteNet();
  output_sensor();
  digitalWrite(LED_CENTRE, HIGH); //LED eye on
  randomOpen = random(3, 6);// pick random opening comment
  mp3.playMp3FolderTrack(randomOpen); // play random "I see you" comment
  output_sensor();
  delay (3400);
//====================FALSE ACTIVATE ============================//
void falseActivate(){ //
  busyRed = 1;
  ReadNet();
  WriteNet();
  output_sensor();
  randomFalse = random(6, 9);// pick random opening comment
  mp3.playMp3FolderTrack(randomFalse); // play random "where'd you go?" comment
  delay (1800);
//======================= SCAN AREA =============================//
void scanArea(){ // continue scanning for a bit after falseActivate
  busyRed = 1;
  ReadNet();
  WriteNet();
  output_sensor();
  mp3.playMp3FolderTrack(2); // "searching..."
  delay(1600);
  servo_pitch.detach();
  servo_wings.detach();
  mp3.playMp3FolderTrack(21);
  for (int i=0; i <= 220; i++){ //scan for a little bit...
    output_sensor();
    if (pivotCW == 0) posPIVOT = posPIVOT - 1; // increment one step CW if CW = 0
    if (pivotCW == 1) posPIVOT = posPIVOT + 1; // otherwise go one step other direction
    if (posPIVOT >= maxPIVOT) pivotCW = 0; // if max rotation clockwise, switch to counterclockwise
    if (posPIVOT <= minPIVOT) pivotCW = 1; // if min rotation counterclockwise,switch to clockwise
    servo_pivot.write(posPIVOT);
    if (sensor.readRangeSingleMillimeters()<triggerDistance/2){ //Somebody stepped in front
      i = 350;
      engage();
      delay (2500);
      activate_servos();
        fire(); // shoot them...
  activate_servos(); // fully scanned with no one passing...
  servo_pivot.write(parkPIVOT); //close up.
  output_sensor();
  delay(1200);
//======================= ENGAGE ================================//
void engage(){ //smartass comment before firing
  busyRed = 1;
  ReadNet();
  WriteNet();
  output_sensor();
  randomStart = random(9, 12);// pick random smartass comment before firing
  mp3.playMp3FolderTrack(randomStart);
  output_sensor();
//======================= FIRE ==================================//
void fire(){ // fire sound and turret movement
  ReadNet();
  WriteNet();
  output_sensor();
  mp3.playMp3FolderTrack(15);
  servo_pitch.write(posPITCH);
  digitalWrite(LED_LH_up, LOW);
  digitalWrite(LED_LH_down, HIGH);
  digitalWrite(LED_RH_up, LOW);
  digitalWrite(LED_RH_down, HIGH);
  delay(pulse*2);
  digitalWrite(LED_LH_up, HIGH);
  digitalWrite(LED_LH_down, LOW);
  digitalWrite(LED_RH_up, HIGH);
  digitalWrite(LED_RH_down, LOW);
  delay(pulse);
  increment_servos(); // update servo position
//======================= DISENGAGE =============================//
void disengage(){ //re-align wings (pitch) and pivot home before closing wings
  busyRed = 1;
  ReadNet();
  WriteNet();
  output_sensor();
  delay(2000);
  randomDisengage = random(12, 15);
  mp3.playMp3FolderTrack(randomDisengage); // "Goodbye" comment
  digitalWrite(LED_RH_down, LOW); // turn off firing LEDs
  delay (2000);
  delay (1500);
  digitalWrite(LED_CENTRE, LOW); // turn off central LED
  delay (100);
  output_sensor();
  turn_off_servos();
  busyRed = 0;
void turn_off_servos(){ // detach servos so they're not engaged
  servo_pivot.detach();
void activate_servos(){ // activate servos for movement
  servo_pivot.attach(PIVOT);
  servo_pitch.attach(PITCH);
  servo_wings.attach(WINGS);
//======================= CARA MIA OPERA ========================//
void Cara_Mia(){
  busyRed = 1;
  WriteNet();
  int randomWingPos;
  activate_servos();
  unsigned long endTimer[] = {8200, 40000, 100000}; //
  unsigned long startTimer;
  for (int i=0; i <= 2; i++) {
    startTimer = millis();
    mp3.playMp3FolderTrack(100 + i);
    while (millis() < (startTimer + endTimer[i])){
      ReadNet();
      WriteNet();
      if (payload[4] == 0) {
        disengage();
        busyRed = 0;
        WriteNet();
        return;}
        //  debugging print below.  Delete or comment out as desired.
      Serial.print(F("millis() ")); Serial.print (millis()); Serial.print ("   ");
      Serial.print(F("startTimer ")); Serial.print (startTimer); Serial.print ("   ");
      Serial.print(F("endTimer ")); Serial.print (endTimer[i]); Serial.print ("   ");
      Serial.print(F("End Time ")); Serial.print (endTimer[i] + startTimer); Serial.print ("   ");
      Serial.print(F("previousMillis1 ")); Serial.print (previousMillis1); Serial.print ("   ");
      if ((millis() - previousMillis1) >= (850 + (i * 100))) { // 1050
        randomWingPos = random(10 + (i*20), (60 + (i*20)));
        servo_wings.write(randomWingPos);
        previousMillis1 = millis();
  disengage();
  busyRed = 0;
  goState = 0;
  mp3.stop();
  ReadNet();
//======================= CHATTY TIME ===========================//
void Chatty_time(){
  busyRed = 1;
  WriteNet();
  int i = 0;
  int talk;
  int saying;
  int timeadder = 750;
  int talkTime = NormalTimings[i];
  int randomPivotPos;
  activate_servos();
  do {
    ReadNet();
    WriteNet();
    //output_sensor(); //  used for debugging...
    if (i >= 43) { // end of sequence
      busyRed = 0;
      WriteNet();
      disengage();
      return;
    unsigned long currentMillis = millis(); // grab current time
    if ((unsigned long)(currentMillis - previousMillis3) >= talkTime) {
      if (chatSayings[i] < 100) { // RED Turret talking
        talk = chatSayings[i];
        saying = chatSayings[i];
        talkTime = (NormalTimings[saying] + timeadder);
      else if ((chatSayings[i] > 99) && (chatSayings[i] < 200)) { // WHITE turret talking
        talk = 0;
        saying = chatSayings[i] - 100;
      else {  // BLUE turret talking
        talk = 0;
        saying = chatSayings[i] - 200; // sound file # of BLUE
        talkTime = (DefectiveTimings[saying] + timeadder); // Time for that saying
      if (talk == 0) {
      else {
        mp3.playMp3FolderTrack(talk);
      randomPivotPos = random(minPIVOT, maxPIVOT);
      servo_pivot.write(randomPivotPos);
      Serial.print(F("i: ")); Serial.print (i); Serial.print ("\t");
      Serial.print(F("chatSayings[i] ")); Serial.print (chatSayings[i]); Serial.print ("\t");
      Serial.print(F("Saying ")); Serial.print (saying); Serial.print ("\t");
      Serial.print(F("talk ")); Serial.print (talk); Serial.print ("\t");
      Serial.print(F("chat time ")); Serial.print (talkTime); Serial.print ("\t");
      previousMillis3 = millis();
      i++;
  while (payload[4] == 1);
  busyRed = 0;
  WriteNet();
  disengage();
//======================= MANUAL CONTROL =======================//
void ManualControl(){
  int servoWings;
  int servoPitch;
  int servoPivot;
  activate_servos();
  ReadNet();
  do {
    output_sensor();
    ReadNet();
    servoPivot = map(payload[0], 1023, 0, minPIVOT, maxPIVOT);
    servoPitch = map(payload[1], 1023, 0, minPITCH, maxPITCH);
    servo_pivot.write(servoPivot);
    servo_pitch.write(servoPitch);
    if (payload[3] == 0) {
      if ((unsigned long)(currentMillis - previousMillis1) >= 2500) {
      randomPic = random(1, 20);
      mp3.playMp3FolderTrack(randomPic);
    if (payload[2] == 0){
      fire();
  while (payload[5] == 3);
  disengage();
  busyRed = 0;
  WriteNet();
//========================= RECEIVING ===========================//
void ReadNet(){
  network.update();
  if ( network.available() )  {
    RF24NetworkHeader header;
    network.peek(header);
    network.read(header, &payload, sizeof(payload));} // Read the package
//========================= SENDING =============================//
void WriteNet(){
  network.update();
  RF24NetworkHeader header4(MTC);
  bool ok4 = network.write(header4, &busyRed, sizeof(busyRed));
/*  if (ok4) { // used for debugging...
    Serial.print("MTC ok4  ");}
  else {
    Serial.print("-------  ");}
Ich bekomme folgende Fehlermeldung:
C:\Users\Dennis\Desktop\pls\pls.ino:170:1: warning: narrowing conversion of '298000' from 'long int' to 'int' inside { } [-Wnarrowing]
C:\Users\Dennis\Desktop\pls\pls.ino:170:1: warning: overflow in implicit constant conversion [-Woverflow]
In file included from C:\Users\Dennis\Desktop\pls\pls.ino:23:0:
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h: In instantiation of 'uint16_t DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::listenForReply(uint8_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; uint16_t = unsigned int; uint8_t = unsigned char]':
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:105:27:   required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::loop() [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify]'
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:429:17:   required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::sendPacket(uint8_t, uint16_t, uint16_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; uint8_t = unsigned char; uint16_t = unsigned int]'
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:192:19:   required from 'void DFMiniMp3<T_SERIAL_METHOD, T_NOTIFICATION_METHOD>::setVolume(uint8_t) [with T_SERIAL_METHOD = SoftwareSerial; T_NOTIFICATION_METHOD = Mp3Notify; uint8_t = unsigned char]'
C:\Users\Dennis\Desktop\pls\pls.ino:191:20:   required from here
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:511:62: error: no matching function for call to 'Mp3Notify::OnPlayFinished(DfMp3_PlaySources, uint16_t&)'
                         T_NOTIFICATION_METHOD::OnPlayFinished(DfMp3_PlaySources_Usb, replyArg);
C:\Users\Dennis\Desktop\pls\pls.ino:37:15: note: candidate: static void Mp3Notify::OnPlayFinished(uint8_t)
C:\Users\Dennis\Desktop\pls\pls.ino:37:15: note:   candidate expects 1 argument, 2 provided
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:515:62: error: no matching function for call to 'Mp3Notify::OnPlayFinished(DfMp3_PlaySources, uint16_t&)'
                         T_NOTIFICATION_METHOD::OnPlayFinished(DfMp3_PlaySources_Sd, replyArg);
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:519:62: error: no matching function for call to 'Mp3Notify::OnPlayFinished(DfMp3_PlaySources, uint16_t&)'
                         T_NOTIFICATION_METHOD::OnPlayFinished(DfMp3_PlaySources_Flash, replyArg);
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:524:66: error: 'OnPlaySourceOnline' is not a member of 'Mp3Notify'
                         T_NOTIFICATION_METHOD::OnPlaySourceOnline(static_cast<DfMp3_PlaySources>(replyArg));
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:529:68: error: 'OnPlaySourceInserted' is not a member of 'Mp3Notify'
                         T_NOTIFICATION_METHOD::OnPlaySourceInserted(static_cast<DfMp3_PlaySources>(replyArg));
C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna\src/DFMiniMp3.h:534:67: error: 'OnPlaySourceRemoved' is not a member of 'Mp3Notify'
                         T_NOTIFICATION_METHOD::OnPlaySourceRemoved(static_cast<DfMp3_PlaySources>(replyArg));
Bibliothek Wire in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire  wird verwendet
Bibliothek VL53L0X in Version 1.3.1 im Ordner: C:\Users\Dennis\Documents\Arduino\libraries\VL53L0X  wird verwendet
Bibliothek SoftwareSerial in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial  wird verwendet
Bibliothek Servo in Version 1.1.7 im Ordner: C:\Program Files (x86)\Arduino\libraries\Servo  wird verwendet
Bibliothek DFPlayer_Mini_Mp3_by_Makuna in Version 1.0.7 im Ordner: C:\Users\Dennis\Documents\Arduino\libraries\DFPlayer_Mini_Mp3_by_Makuna  wird verwendet
Bibliothek RF24 in Version 1.4.2 im Ordner: C:\Users\Dennis\Documents\Arduino\libraries\RF24  wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI  wird verwendet
Bibliothek RF24Network in Version 1.0.16 im Ordner: C:\Users\Dennis\Documents\Arduino\libraries\RF24Network  wird verwendet
exit status 1
Fehler beim Kompilieren für das Board Arduino Nano.
Ich habe bereits alle Programmer ausprobiert.
Vielen Dank für eure Hilfe!
Ich tippe auf eine falsche MP3-Library.
Was Dir nix nützt, denn es wurde ja kein Programm zum Hochladen erstellt:
Da am Ende steht bei Erfolg immer wieviel Programm- und Datenspeicher in Verwendung ist.
Der Callback OnPlayFinished hat bei der installierten Lib nur einen Parameter, du gibst aber zwei an (siehe Post #2)
