I have 5 Fema 14-segment alphanumeric display modules p/n AI20-054SH-LRR-L5.5Z that contains 35 bit shift register. The problem I am having is figuring out how to send data to it via serial.
Here is a code that I found to transmit serial data to the display.
//pin definitions, using the shiftOut function to communicate with the display
const int SDATA = 12; //to SIN on JP1
const int CLOCK = 11; //to CLK on JP1
const int LATCH = 10; //to LAT on JP1
const int BLANK = 9; //to BL on JP1
//BL pin on JP1 MUST be pulled LOW, we will do this in software
//Display brightness can also be controlled through PWM using AnalogWrite function
void setup () {
//set all pins to output
pinMode(SDATA, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(LATCH, OUTPUT);
pinMode(BLANK, OUTPUT);
digitalWrite(BLANK, LOW); //for this example, BLANK is held LOW throughout
//allow DSP-0801's onboard PIC to wake up before sending any data
//send 8 blank digits to clear all registers, not always necessary but good practice
for(int i = 0; i < 8; i++) {
digitalWrite(LATCH, LOW);
shiftOut(SDATA, CLOCK, MSBFIRST, 0x0000); //data must be sent one byte at a time
digitalWrite(LATCH, HIGH);
void loop () {
//defines how fast digits will scroll
int scrollRate = 200;
//character table array - what we want to put on the display goes in here, in this
//case:
//"DSP0801 THE QUICK BROWN FOX JUMPS OVER THE LAZY DOG "
//refer to 14-segment character code document for HEX values
word charTable[55] = {
0x0200, 0x909, 0x00F3, 0x243F, 0x00FF, 0x243F, 0x406, 0x0000,
0x1201, 0x00F6, 0x0079, 0x0000, 0x83F, 0x003E, 0x1209, 0x0039, 0xC70,
0x0000, 0x00BF, 0x8F3, 0x003F, 0x2A36, 0x936, 0x0000,
0x0071, 0x003F, 0x2D00, 0x0000, 0x001E, 0x003E, 0x1536, 0x00F3, 0x909,
0x0000, 0x003F, 0x2430, 0x0079, 0x8F3, 0x0000, 0x1201, 0x00F6, 0x0079,
0x0000, 0x0038, 0x00F7, 0x2409, 0x1500, 0x0000, 0x120F, 0x003F, 0x00BD,
0x0000, 0x0000, 0x0000, 0x0000
//get characters from array one at a time ready to be shifted out
for(int index = 0; index < 1; index++){
word charData = 0x3f00; //charTable[index];
//shift out the value currently held in charData
shiftOut(SDATA, CLOCK, MSBFIRST, (charData >> 8)); //send one byte
shiftOut(SDATA, CLOCK, MSBFIRST, charData); //then the other
delay(scrollRate);
I try to work out a data table for it and not having much luck spent 3 hours searching on the web for information.
here is the Serial Data input sequence.
I can activate Segment A-E but when I try to activate F to make a zero segment G lite instead. If anyone has suggestion please let me know.
Thanks
I will still search the internet for answer.
