Few Electronic Question about power!
hi,
this is the only place i know that i can ask this ! sorry if its unrelated!!
im a little confused
1.if i put a resistor does it ONLY decrease the amperage? what to do to only limit my motors ampere usage without changing voltage? so i can run it from usb ! i don't care if the power is less (if it spins not good as full current)
2.how can i increase current (i don't care if voltage gets lower) i want to charge a phone with panel, when i connect it to switching regulator, it gets like from 100 amper to 90 or 80 amper (on bad lighting)
my panels are 9v and 12v , i want to make them 5v anyway, but current gets even lower!
  1. if i want to increase voltage when its low and make it 5v when its higher, what should i do? so my phone doesn't keep going off and on ! (i can connect it to AA batteries and make the AA batteries charge my phone !or some lipo !)
edit: sorry, i see it now(mistakes in my post) :expressionless: i was so sleepy last night :smiley:
1 ) You can use a resistor to lower the current to something small. A normal led can be set bright or dim with a resistors. A motor needs more current, and a resistor will get hot and will waste a lot of energy. You can not run a heavy motor from the usb power.
2 + 3 ) Are you talking about a solar panel ? Is that a very small solar panel of 100mA (milliAmpere) or is that a large solar panel on a roof of 100A ?
It is possible to make a lower voltage (with more current) with a DC-DC converter. You can also increase the voltage (with less current), and some DC-DC converters allow a stable output, while the input could be lower or higher.
This is such a "anything" to 5V converter : VERTER 5V USB Buck-Boost - 500mA from 3V-5V / 1000ma from 5V-12V : ID 2190 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits
It seems like you have to build a conceptual model of what electricity really is. Electricity is a form of energy. And it can only be converted into other forms of energy, like heat(resistors) light (leds) mechanical energy (motors) and electrical energy of another voltage(transformers and switching regulators).
  • A resistor converts electrical energy to heat. Just like friction converts mechanical energy to heat. Connecting a resistor in series incraeses the total resistance, thus lowering the current and introducing a voltage drop. The electrical power (=rate of energy conversion) converted to heat in the resistor is the current * voltage drop (P=U*I)
  • A switching regulator conserves energy while changing the voltage. But the process is not lossless. Your post was a bit hard to comprehend. The currents on the input side of the regulator (=output of solar panel) will be lower than on the output side of the regulator (=output to phone). So your post makes sense if we assume that you are comparing the output of the panel between direct connection and inserting a switching regulator. But the charging current should be larger with the regulator
  • You will have to use a stepup or boost regulator
Peter_n:
This is such a "anything" to 5V converter : VERTER 5V USB Buck-Boost - 500mA from 3V-5V / 1000ma from 5V-12V [TPS63060] : ID 2190 : Adafruit Industries, Unique & fun DIY electronics and kits
wow awesome :smiley: thanks
my solar panels are 12v both but gives 150a @ 10v at a good day here :expressionless: (its winter now, today is completely cloudy, i can't test again xD)
i don't think i can find that here, but i will try to find similiar one :slight_smile: or make one myself if its simple !
i have a dc dc converter adjustable step down, but it makes current like 10% lower than full voltage ! i think its supposed to bring it higher !? what am i doing wrong?
nilton61:
then why is my Regulator's output current lower than solar panel's output current?(attaching the multiplier directly to panel (like short circuit)
Please stop what you are doing.
You are testing with a current of 150A ? That is dangerous, the wires could melt.
A DC-DC converter that can handle a current of 150A should be a professional and certified device, installed by a qualified person.
When you want to test the shortcut current of a converter output, you better use a simple and small solar panel (about the size of a letter) that you use to test with.
loool :smiley: im so sorry im such an idiot, i ment 150ma :smiley: not A lol , i don't think any solar panel can make that current :D(jk). I always make that mistake :slight_smile:
1- I=E/R where a resistor increases R and decreases I as a result . So V won't change . Decrease V with Diodes , voltage drop . Beware that does affect I anyway .
2- I suppose OP-AMP or something like that .
Regulate them to 5v with a 'regulator'
3- A micro-controller + voltage detection module thingymajig , and drivers . In this case , a FET maybe even a BJT transistor might/would work but for higher voltages , it's cheaper and much more reliable to use relays .
You should just program the arduino to read the voltage and make a decision based on the value (stored in a variable )
Or if your phone needs 5v , you can regulate it . You might be able to use capacitors to store energy when there is extra and emit current when it's low .
Of course a battery is a much better choice . A Power bank is the best .
Besides , I'm not sure if amperage is a correct word . Widely used but I think Amp(s) is better .
kamhagh:
Okay, that's better ! 8)
But still, you can not measure the shortcut current to know something about the current output of a DC-DC converter. A good DC-DC converter might be protected against shortcut and might lower the current.
You could use two DC-DC converters, one to lower the voltage from the solar panel and one to increase the voltage from batteries. Or such a "anything" to 5V from Adafruit.
I assume that when the 9V and 12V solar panels are below 5V, they have so little current that you can not use it anyway.
The most common way is this: Use a large battery. For example a single Li-ion cell of 3.7V. Use a solar-to-battery-charger, so the battery is charged by the solar panels. This must be a special charger, so no current will flow back into the solar panel. The battery is then used to make other voltages. So when you need 5V, a normal DC-DC converter is used to turn the 3.7V into a useful 5V.
That means that for an output of 5V, the 12V of the solar panel is first converted into battery voltage and after that into 5V. It is a safe and common way to do it like that.
Peter_n:
That's a great idea thanks :smiley: im going to do that. But a simple question, How can i charge and use the Lipo to charge my nexus 4 at same time ? :slight_smile: (so i don't damage the lipo :|)
It should be no problem, to do that at the same time.
At www.adafruit.com they have a circuit board that does that. You add a Lipo or Li-ion cell and a solar panel. They show it at the end of a Youtube movie from Collin about solar energy.
Can you google for : collin lab solar adafruit
If you have 200W solar panels on the roof, at 10V , that's 20 A per panel so it would actually only take 8 panels to get 150A at 10V.
Many of the comments on the above solar forum pertain to 5kW solar systems, capable of 500A @ 10V.
(of course the capacity per panel is only 200W)
You need to store the energy in a 12V battery and convert that to 5V with a regulator.
How much current do you need at 5V ?
The symbol for the ampere is A not a. Thus you have mA, A, never ma or a.
All physical quantity single-letter symbols have a particular case and it usually matters.
For instance v is velocity, V is volts.
The full word symbol is almost always lower case, ampere, volt, farad, henry, ohm,
though getting this wrong isn't so confusing.
i found that the case, upper or lower, depend on whether the quantity was named after a person or not. Thus volt has a Capital V, ampere has a capital A, meter has a lowercase m and seconds have a lowercase s.
nilton61:
meter has a lower case m
Strictly speaking, a meter is a piece of equipment we use to measure things.
Just sayin ...
Here in europe a meter also is the basic unit for length/distance. Homonyms can be confusing
nilton61:
Here in Europe a meter also is the basic unit for length/distance.
No, it isn't. :o
nilton61:
Sure are! That one has you confused for a start! :grinning:
So then please tell me, what is the base unit for length/distance in the SI system?
Meter is the most widely used unit for length .
