Hello,
as the heading says I am a little bit confused whether or not my problem is completely normal or not.
So I am currently trying to visualise some music on WS2812B LED strips with the Adafruit Neopixel library and in order to capture the music I use the MAX9814 microphone, which is from Adafruit as well. I process the sound with this library:
I will post the code to obtain the frequency using FFT below. My questions are:
- Is it normal that when there is no music/noise at all, the values kinda "jump" and are pretty random? If not, do you have any ideas on what's wrong with the code?
- Since I am not 100% sure how the algorithm of FFT completely works I would like to know why the higher the 'SAMPLING_FREQUENCY' the higher the base value when there is silence. For example, if I set it to 1000, I will get a value of around 50 or so when there is silence. So it prints out 50Hz to be the major peak in complete silence. If I set it to 5000 or more however, the major peak is considered to be higher, like at 200Hz.
- It would also be interesting to know why there is a comment next to that which says that the Hz must be less than 10.000 due to ADC. Why is that the case?
#include "arduinoFFT.h"
#define SAMPLES 512 //Must be a power of 2
#define SAMPLING_FREQUENCY 7500 //Hz, must be less than 10000 due to ADC
arduinoFFT FFT = arduinoFFT();
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[SAMPLES];
double vImag[SAMPLES];
sampling_period_us = round(1000000*(1.0/SAMPLING_FREQUENCY));
/*SAMPLING*/
for(int i=0; i<SAMPLES; i++)
microseconds = micros(); //Overflows after around 70 minutes!
vReal[i] = analogRead(0);
vImag[i] = 0;
while(micros() < (microseconds + sampling_period_us)){
/*FFT*/
FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
double peak = FFT.MajorPeak(vReal, SAMPLES, SAMPLING_FREQUENCY);
/*PRINT RESULTS*/
//Print out what frequency is the most dominant.
Serial.println(peak);
delay(100); //Repeat the process over and over
Oh, and by the way: Im using a NodeMCU and not an Arduino, if that matters.
I know that those are a lot of questions, but it would be nice if there is anyone, who can answer one of them.
Thanks in advance.
