FFT output for noise sensor shifts after some time
I am using a noise sensor (ADMP401) along with Arduino Mega. I use openmusiclabs FFT algorithm to convert the noise sensor analog output to frequency domain, then remove the first 30 bins (to remove some board noise), then calculate the rms value of the remaining bins. So, during a period of 10 seconds (which is my polling period), I have a set of 12 rms values from which I take the median value to get the ambient noise equivalent.
Its working fine and I can see the output value responding to noises. I usually get an output of around 7 to 10 for silent conditions. The problem is, for some units, this base value of 7 to 10 shifts to around 2 to 3 after running for some time and then will remain at that lower level. Still the sensor will respond to noises. But since this shifting is happening, I am unable to correlate the output to dB levels.
I set the prescaler to 32 and 38.4kHz sampling rate
ADCSRA = bit (ADEN) | bit (ADSC) | bit (ADIF) | bit (ADPS2) | bit (ADPS0)
256 point FFT
Below is my code:
void Update_ADMPFFT(){
//Setup bit read
ADCSRA = bit (ADEN) | bit (ADSC) |bit (ADPS2) | bit (ADPS0);
ADMUX = 0x42; // Use A2 where ADMP401 is connected to
while(!(ADCSRA & 0x10)); // Wait for ADC to be ready
// Restart adc, clear flag and  set the prescaler to 32 and 38.4kHz sampling rate
ADCSRA = bit (ADEN) | bit (ADSC) | bit (ADIF) | bit (ADPS2) | bit (ADPS0);
byte m = ADCL; // Fetch adc data
    byte j = ADCH;
    int k = (j << 8) | m; // Form into an int
    k -= 0x0200; // Form into a signed int
    k <<= 6; // Form into a 16b signed int
   fft_input[lCounter] = k; // Put real data into even bins
   fft_input[lCounter+1] = 0; // Set odd bins to 0
    lCounter  = lCounter + 2; // Increment counter until 512
    if (lCounter == 510){
    //Once data is filled in, do FFT
     fft_window(); // Window the data for better frequency response
       fft_reorder(); // Reorder the data before doing the FFT
       fft_run(); // Process the data in the FFT
       fft_mag_lin(); // Take the output of the FFT
       //Filter out the first 30 bins which includes the board noises
       for (byte i = 31; i < FFT_N/2; i++) {
       //Use this after using fft_mag_lin() for finding rms of magnitude power
       rms = rms + (fft_lin_out[i]* fft_lin_out[i]);
       //Find rms value of the remaining 97 bins.
       rms_sum = sqrt(rms/97);
      lCounter = 0;
    //Reset summation variables
    rms = 0;
    rms_sum = 0;
Has anyone experienced this kind of behavior while working with noise sensors and FFT?
There's someone with a very similar problem here
How weird. It is the SAME person!
Imagine that.
