John thank you for your help! I now have an FHT code that works to some degree and the rest of my code.
I now have the problem that when i compile them together, what I am assuming is to do with the FHT setup code, is messing around with my LCD display.
#include <LCD4Bit_mod.h>
LCD4Bit_mod lcd = LCD4Bit_mod(2);
#define LOG_OUT 1 // use the log output function
#define FHT_N 256 // set to 256 point fht
#include <FHT.h> // include the library
float StrI[] = {285.43, 329.63, 369.99};
float StrII[] = {220.00, 246.94, 285.42};
float StrIII[] = {169.81, 196.00, 219.99};
float StrIV[] = {127.47, 146.83, 169.61};
float StrV[] = {95.25, 110.00, 127.57};
float StrVI[] = {65.406, 82.407, 95.15};
float Strings[] = {73.416, 95.00, 128.00, 170.00, 220.00, 285.00, 392.00};
float a = Strings[0];
float b = Strings[1];
float c = Strings[2];
float d = Strings[3];
float e = Strings[4];
float f = Strings[5];
float g = Strings[6];
float x;
float h = 0;
float l = 0;
float jp = 0;
void setup(){
TIMSK0 = 0; // turn off timer0 for lower jitter
ADCSRA = 0xe6; // set the adc to free running mode
ADMUX = 0x41; // use adc1
DIDR0 = 0x02; // turn off the digital input for adc0
pinMode(13, OUTPUT);
lcd.init();
lcd.clear();
lcd.printIn("Guitar Tuner");
lcd.clear();
lcd.printIn("By Liam Simpson");
lcd.clear();
lcd.printIn("E,A,D,G,b,e?");
delay(3000);
lcd.clear();
void loop(){
while(1) { // reduces jitter
cli(); // UDRE interrupt slows this way down on arduino1.0
for (int i = 0 ; i < FHT_N ; i++) { // save 256 samples
while(!(ADCSRA & 0x10)); // wait for adc to be ready
ADCSRA = 0xf5; // restart adc
byte m = ADCL; // fetch adc data
byte j = ADCH;
int k = (j << 8) | m; // form into an int
k -= 0x0200; // form into a signed int
k <<= 6; // form into a 16b signed int
fht_input[i] = k; // put real data into bins
fht_window(); // window the data for better frequency response
fht_reorder(); // reorder the data before doing the fht
fht_run(); // process the data in the fht
fht_mag_log(); // take the output of the fht
sei();
Serial.write(255); // send a start byte
int j = 0;
int k;
for (int i = 0; i < FHT_N/2; i++) {
if (fht_log_out[i] > j) {
j = fht_log_out[i];
k = i*150;
x = k;
Serial.println(x);
Serial.println(x);
if(x > Strings[0] && x < Strings[1]) {
float h = StrVI[1];
float l = StrVI[2];
float jp = StrVI[0];
lcd.cursorTo(1,0);
lcd.printIn("E");
if(x > h+1 && x < l) {
lcd.cursorTo(2,0);
lcd.printIn("Sharp");
else if(x < h-1 && x > jp) {
lcd.cursorTo(2,0);
lcd.printIn("Flat");
else if(x >= jp-1 && x <= l+1){
lcd.cursorTo(2,0);
lcd.printIn("Bingo!");
else{
lcd.cursorTo(2,0);
lcd.printIn("Undetectable");
lcd.clear();
if(x > Strings[1] && x < Strings[2]) {
float h = StrV[1];
float l = StrV[2];
float jp = StrV[0];
lcd.cursorTo(1,2);
lcd.printIn("A");
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
else{
lcd.cursorTo(2,0);
lcd.clear();
if(x > Strings[2] && x < Strings[3]) {
float h = StrIV[1];
float l = StrIV[2];
float jp = StrIV[0];
lcd.cursorTo(1,4);
lcd.printIn("D");
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
else{
lcd.cursorTo(2,0);
lcd.clear();
if(x > Strings[3] && x < Strings[4]) {
float h = StrIII[1];
float l = StrIII[2];
float jp = StrIII[0];
lcd.cursorTo(1,6);
lcd.printIn("G");
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
else{
lcd.cursorTo(2,0);
lcd.clear();
if(x > Strings[4] && x < Strings[5]) {
float h = StrII[1];
float l = StrII[2];
float jp = StrII[0];
lcd.cursorTo(1,8);
lcd.printIn("b");
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
else{
lcd.cursorTo(2,0);
lcd.clear();
if(x > Strings[5] && x < Strings[6]) {
float h = StrI[1];
float l = StrI[2];
float jp = StrI[0];
lcd.cursorTo(1,10);
lcd.printIn("e");
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
lcd.cursorTo(2,0);
else{
lcd.cursorTo(2,0);
lcd.clear();
This is my code so far. I’m not sure which parts are conflicting so I had to just put it all in.
I’m also only using it with frequencies between 73-400Hz, is there anything I can change to give it a higher resolution within that bandwidth?
Thanks.
