Fibaro distance sensor
Hello…I have an Arduino Uno with distance sensor which i have coded and works as it should. I need to get the distance information out of the Arduino to use with a Fibaro RGBW sensor for some home automation. The Fibaro reads 0-10V.
Can anyone help with this please??
Thank you.
A what? (hint)
The Fibaro RGBW accepts 0 - 10v on an input which I need to use to tell my system the distance from the sensor connected to the Arduino.
How fast do you need the result?
If a few hundred mS, the PWM output with a simple Low pass filter and an amplifier should do the job
regards
Allan.
thanks fir that i will try that, cheers
