i Have been trying to get two MPU6050's working on one board for a couple of weeks now. I have got to the point where both devices are being recognised, i have labelled both as separate variables in the code and gone through and duplicated the code with both devices hab=ving separate calls. However, when i run the code, it gives the printout below in the serial monitor;
Initializmo:
MPU6050 connection successful
MPU6050 2nd connection successful
Send any character to begin DMP programming and demo:
InInitializing I2C devices...
Testing device connections...
Initializing DMP...
Enabling DMP...
Enabling interrupt detection (Arduino external interrupt 0)...
DMP ready! Waiting for first interrupt...
Initializing DMP 2 ...
Enabling DMP 2...
DMP 2 ready! Waiting for first interrupt...
FIFO overflow!
i have tried the following to resolve this;
-used a mega 2560 instead of an Uno R3
-changing the last byte in the MPU6050_6Axis_MotionApps20.h file (FIFO Overflow - MPU-6050 6-axis accelerometer/gyroscope (InvenSense) - I2Cdevlib Forums)
-changing the FIFO Storage Buffer
-changing the I2C clock to
-Changing fastwire from 400 to 200
-changing baud rate, down to 9600, and up to 500000
-deleting the serial.print function for worldaccel to reduce program size.
-adding in a delay after the serial.print
basically i have got nowhere in trying to sort this issue, and already missed this weeks opportunity to do my experiment. (using the accelerometers for my dissertation research)
i know that the data is not being read fast enough, but don't know how to solve it, so someone pointing me in the right direction would be a great help. Thanks
