Figaro TGS2442 CO sensor help
hi, i have been trying to make an air quality sensor using the figaro tgs 2442 sensor. however i am a bit confused with a the wiring diagram and the code.
the wiring diagram i used is similar to this: http://habitatmap.org/habitatmap_docs/HowToBuildAnAirCastingAirMonitor.pdf
i wired only the CO sensor for now. and the code is as mentioned below.
the output i get seems to be very wrong. i attached the output image here as well.
CO Meter
for Arduino UNO R3 & IDE 1.0.5
by Flavio ... 07/07/2013
int FigaroHeater = 6; // Heat VCC
int FigaroCircuit = 5; // Sensing VCC
int FigaroCOPin = A0;
byte N = 10; // numero di campioni
int Somma; // somma dei campioni (max 32767)
int FigaroCOVal = 0;
pinMode(FigaroHeater, OUTPUT);
pinMode(FigaroCircuit, OUTPUT);
pinMode(FigaroCOPin, INPUT);
void loop( ) {
digitalWrite(FigaroCircuit, LOW); // turn OFF sensing VCC
analogWrite(FigaroHeater, 245); // turn ON heating (recommended 4.8 volts)
delay(14); // heating time
analogWrite(FigaroHeater, 0); // turn off heating
delay(981); // ritardo prima attivazione di lettura
digitalWrite(FigaroCircuit, HIGH); // turn ON sensing VCC
delay(3); // ritardo prima della lettura
Somma = 0;
for (byte I = 0; I < N; I ++) { // ciclo di letture (@ 8620 sample/s)
Somma += analogRead(FigaroCOPin);
FigaroCOVal = Somma / N; // media per eliminazione "rumore" ed errore su prima lettura
Serial.println(FigaroCOVal);// display result (0-1023)
int RL=39000;
int RS;
int Vo = (FigaroCOVal*5)/1024;
RS = ((FigaroCircuit*RL)/Vo);
int COppm = 100/RS;
Serial.println("CO ppm: ");
Serial.println(COppm);
delay(2000);
First: Please edit your post and insert code tags!
Why is the output pin number used in the formula?
Don't use integer variables if you think yourself in floating point numbers. Your Vo value will be 1 or 2, probably not the accuracy you expected.
int RL=39000;
An int variable cannot hold such a big number.
hi i should adjust those then. Thank you! do you know the proper wiring diagram for this sensor?? because i cannot understand where the input A0 connects to the sensor
I thought you're using the wiring as in the tutorial you linked to? A0 is connected between the sensor and the external resistor.
