JohnRob:
Your issue is the common mode voltage of the LM339 is Vs - 1.5 V.
This means both the + and - inputs cannot go above 3.5V when powered with 5V.
This is a very old part. I'm sure there are newer comparators available that are designed for 5V operation (with a larger common mode voltage). I don't know any off hand but perhaps digikey website can help.
Okey so summed up my VREF cant go higher then 3.5V ?
Grumpy_Mike:
Then why does the diagram say it uses a LM393?
I guess LM393 and LM339 are the same comperators only difference LM339 has 4 of them integrated
larryd:
An LM339/393 is still a good comparator for this.
I like using the inverting 339 comparator circuit.
Your R1 should be close to the parallel value R4 and R5.
You may have to tune the hysteresis.
With Vcc = 5V
“ change the R5 to 39kOhm so that way VREF is 4V ?”
39k is reasonable.
Show us your wiring with the 39k
Try 3.5v as mentioned.
As im doing this in school i will try tommorow chaning VREF to about 3.5V and afterward make a picture if it still doenst work. But finally I got an clue what it could be thanks to you guys.
jremington:
As stated in reply #2, the LM339 comparator WILL NOT WORK with 4V on the inputs, if powered by 5V.
Use a 9V power supply for the comparator instead of 5V.
So if use then a 9V Power Supply will the output will jump onto 9V? or am i wrong?
//EDIT: And yea i measured VREF 4V are on it
One more question where can i find Vs= 1.5 V in datasheet so if needed i can look for a different comperator? What is it normaly named? Cause in the LM393 or LM339 Datasheets i cant really find it
