I want to control a 12V light bulb. Powersource for the bulb is is a 12v 1.6A wall adapter.
Now, I'd like to figure out which transistor, switch i can use to control the power to the bulb through the arduino. But my questions is a little more generic, is there some sort of a tool where i can plugin all the values of the inputs/outputs and it will point me to the part number that i could use?
On top of that, if anyone can point me to a descent tutorial on how to use a transistor or a MOSFET, that would be great. (I've tried wikipedia, and it's not the greatest place to learn from)
Thank you.
You need a FET with a voltage rating (BVDSS) greater than 12V, a current
rating (IDmax) greater than the current required from the lamp and a logic
level input.
There are a lot of FETs that can do this. One that was discussed in another
thread was the FDP8878 -- TO220, 30V, 40A, logic level input. It is apx $1 from Digikey.
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
Gotcha, i'll look for that MOSFET, i was using IRF520A for a smaller LED setup, i'm wondering if that would work for the lamp.
The way it worked for me for USB LEDs went like this
Gate: Arduino Digital out
Source: Negative cable to LED/small motor mount
Drain: Negative lead from USB
Positive cable connected on its own.
When i tried to repeat the same setup, but using the 12v power adapter, the light was always on, it would not turn off when Arduino told it to.
I skimmed through the data sheet, and it seems to be alright, but i guess i misread something somewhere.
Thanks for the help
The IRF520 may work but you are better off with a logic level FET. The logic
level FET is designed to be "on" at a logic levels. The IRF520 looks like
it has a 10V gate drive.
Also the IRF520 is a 100V device which is much higher than you need.
Using a higher voltage device will give you a higher on-resistance. Choosing
a 30V device would be better.
I would add a pull-down resistor on the gate -- 10K to 100K from gate to source.
This will insure the FET is off until the Arduino output goes high.
(* jcl *)
