Can somebody help me.
Everytime i get the same error.
Include expects “FILENAME” or
This is the code
Random Target
By Dadudos
Made for Bunker501
This code is in the public domain.
Please practice safely!
Last edit 31/3/2021
By Dadudos
#include
Servo myservo_1; // create servo object to control a servo
Servo myservo_2;
Servo myservo_3;
Servo myservo_4;
Servo myservo_5;
Servo myservo_6;
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
long servonummer; // het nr dat de random functie gaat geven
myservo_1.attach(3); // attaches the servos on pins to the servo objects
myservo_2.attach(5);
myservo_3.attach(6);
myservo_4.attach(9);
myservo_5.attach(10);
myservo_6.attach(11);
myservo_1.write(90); //reset alle kaarten naar achteren
myservo_2.write(90);
myservo_3.write(90);
myservo_4.write(90);
myservo_5.write(90);
myservo_6.write(90);
delay(2500);
servonummer = random(0, 7); //kiest het servonummer
if (servonummer == 1) { //kijkt of het nr 1 is of niet. Als het nr 1 is, dan servo open.
myservo_1.write(0); // zet servo op open positie
delay(1500); //tijd dat de kaart zichtbaar blijft.
myservo_1.write(90); //breng servo naar gesloten positie
delay(500); //tijd tussen 2 kaarten
} else if (servonummer == 2) { //als servo 1 niet gekozen is, kijkt hij of servo 2 is gekozen
myservo_2.write(0); // en doet die open.
delay(1500);
} else if (servonummer == 3) { // zie vorige opmerking maar dan +1
myservo_3.write(0);
delay(1500);
} else if (servonummer == 4) {
myservo_4.write(180);
delay(1500);
} else if (servonummer == 5) {
myservo_5.write(180);
delay(1500);
} else if (servonummer == 6) {
myservo_6.write(180);
delay(1500);
Some software (such as comment threads on blogs) eats any text wrapped in <> because it thinks it's HTML tags. So when you copy/paste code that was posted there, it is missing all the angle bracket enclosed code (most commonly #include directives).
That problem is solved now,
Now I got the next error :
Arduino:1.8.12 (Mac OS X), Board:"Arduino Uno"
De schets gebruikt 2896 bytes (8%) programma-opslagruimte. Maximum is 32256 bytes.
Globale variabelen gebruiken 69 bytes (3%) van het dynamisch geheugen. Resteren 1979 bytes voor lokale variabelen. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Probleem bij het uploaden naar het board. Zie http://www.arduino.cc/en/Guide/Troubleshooting#upload voor suggesties.
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
