Can anyone point me at some good file handling examples for the SD card on the Yun? I don't have a lot of linux experience so I'm struggling to know what sort of paths I should be using.
Many thanks
David
Many thanks
David
My experience is also limited, so I just follow some tutorials.
For example this Python script will write a file to the SD card:
#!/usr/bin/python
# Open a file
fo = open("/mnt/sd/test.txt", "wb")
fo.write( "Line 1\n");
fo.write( "Line 2\n");
fo.write( "Line 3\n");
fo.write( "Line 4\n");
# Close opend file
fo.close()
If you need to do simple things, consider taking a look at the datalogger example (one of the Bridge examples)
A rule of thumb is to have a SD card with an "arduino" folder plugged in, so that the Yun makes folder /mnt/sd available, and use yun flash as least as possible
Thanks. That's really useful. I'll give it a try.
David
for Read
File dataFile = FileSystem.open("/mnt/sd/Arduino/www/sample/file.txt");
text="";
while (dataFile.available()) {
text=text + (char)dataFile.read();
dataFile.close();
for write
File dataFile = FileSystem.open("/mnt/sd/Arduino/www/Sample/file.txt", FILE_WRITE);
dataFile.seek(0); //only to write from the beginning of file
dataFile.print("Hello!");
dataFile.close();
if you have to pass a string as the file path use this code
String path="/mnt/sd/Arduino/www/Sample/" + STRING +".txt";
File dataFiles = FileSystem.open(path.c_str());
All your advice really helped. I've got the programme working now.
Many thanks
David
2 years later and still helpful!
Thank you, I needed:
And you beat me to it!
